Bob has modified BLRF (2.0.70) so the HS3 Device Status shows door sensors actual time a door last opened, not the hourly "heartbeat" Closed signal. This is an important feature for me to see when a door last opened.
If this is your first visit, be sure to check out the FAQ. You must register before you can post.
IMPORTANT: Your first post will be checked for appropriate content. This may take a bit of time.
