Hi Toby,
Just got the plugin working again so thanks for re-uploading.
I've managed to migrate the settings over relatively easily, but for one of my curtains, the control isn't working any more. I've tried how I remember to program it (press the program button on the remove, wait / confirm that it jogs on the curtain, press the program button in the web page, confirm that it jogs) but this doesn't appear to be working.
I migrated the channels over 1-1 and the rest worked, but this one didn't (channel 2)
I also tried adding it on another channel (channel 9) which appeared to already have a programming on it/was not being used or configured in the plugin/was controlling an awning that was also on another channel, but whilst this added it fine and I could then control the unit, it added it to the control of the existing channel.
I'm therefore thinking what when the plugin is programming the RS485, it is adding it to the existing channel, rather than clearing the existing channel and then adding it. Not sure if this process is possible, but this is definitely what i'd be wanting in this case at least, or alternatively the ability to clear a channel as needed prior to starting programming.
I then tried to program it on a higher number channel (i.e. 11) but this appeared to have the same problem as channel 2.
Grateful if you can please:
- Advise correctly how to program / advise how i can troubleshoot this
- Advise if there is a way to clear the channels
- Consider providing a FAQ as a sticky with the instructions on how to use
Kieran
Kieran
