Somfy Tahoma
    Somfy Tahoma
    Does anyone know if this plugin works with the Somfy Tahoma?
    K.
    Unfortunately it does not...
      You can go the Node-RED route.
      ___
      John
        That looks like scary programming stuff.
        Somfy say that the Tahoma supports IFFTT so, theoretically, I should be able to send commands by using IFFTT although it'd be arguably slower and dependent on yet another service in the way.
        My problem is I am limited to using that Tahoma (from all I can research) as I want to control solar powered Velux window blinds and, so far as I can see, this is the only way to get them to talk to anything outside the switches they come with. So, my options are limited.
        K.
          I will call it configuration
          John
