RFXLAN Problem?
  • RFXLAN Problem?
    Afternoon Bert,
    I'm having a problem with my RFXLAN - when I connect to RFXMGR I don't get any received protocols at all and I can't select any of the protocols. Am I doing something wrong?
    Cheers
    Scott
    You have to use the RFreceiver and RFXmitter programs.
    RFXmngr is for the RFXtrx and RFXrec devices.
      Thank You Bert, I have found that now. Thank You
      Is there any plan for a replacement to the RFXLAN?
      Cheers
      Scott
        The easiest solution for a replacement is the RFXtrx433E connected to a small Linux system for example a Raspberry PI with ser2net installed.
        Attached the installation instructions for ser2net.
          OK. Thank you again for the help Bert. Cheers, Scott
            Hi Bert,
            This is something I would be interested in,as I need to extend the range of my RFXtrx433E. Current it is upstairs plugged into my HS3 PC via USB. I have an unused PI3. Does this mean I could put the PI and RFXtrx433E downstairs and it could communicate back to HS3 PC wirelessly??
            Regs
            Liam
              Hi,
              you can probably use ser2net but I have no knowledge of WiFi on the RPI. I guess you know how to configure WiFi.
              here the installation instructions for ser2net:
              Disable Serial Console (if configured)
              sudo nano /etc/inittab
              insert a # sign in front of this line:
              T0:23:respawn:/sbin/getty -L ttyAMA0 115200 vt100
              ctrl-O
              Enter
              ctrl-x
              Remove console (if configured)
              sudo nano /boot/cmdline.txt
              delete these 2 fields: console=ttyAMA0,115200 kgdboc=ttyAMA0,115200
              ctrl-O
              Enter
              ctrl-x
              Add ser2net
              sudo apt-get install ser2net
              sudo nano /etc/ser2net.conf
              10001:raw:0:/dev/ttyUSB0:38400 8DATABITS NONE 1STOPBIT
              10002:raw:0:/dev/ttyUSB1:38400 8DATABITS NONE 1STOPBIT
              sudo /etc/init.d/ser2net restart
              Autostart ser2net
              sudo nano /etc/rc.local
              add the next line before exit o :
              /usr/local/sbin/ser2net -n
              Optionally add this line to connect an ACM device to an USB device (if USB not FTDI, for example Microchip MCP2200)
              ln -sf /dev/ttyACM0 /dev/ttyUSB0
              BR Bert
                Bert,
                Thanks for the reply, still wondering how does the PI talk to the homeseer PC, is there a cable from the PC to the remote PI ?
                Regs
                Liam
                  ser2net operates on a LAN connection.
                  If you enable WiFi on the RPI it should be possible to use WiFi.
