Hi
I try to found out if it was possible to send signals to https://bellman.com/en/for-professio...able-receiver/
Because when I use the trigger on Bellman Be1033 It shows like a THC238/268,THN122/132,THWR288,AW129,AW131 Temperature Sensor.
Then I thought maybe was possible to send some code from the rfxcom lan to see if I get any response on be1030.
I open RFXmngr.exe to easy try what signal that works but somehow I click on undec on and set mot Everything els was gray
When I try to connect it back with homeseer my receiver gets stuck in Initializing but my transmitter goes online.
I try to reflash firmware to start from the beginning but nothing has helped
Here are log from HS3
1 Pic Are after I reflash it normal that it say timeout?
2 Pic are what I push to crash everything
3 Pic are my settings for the receiver.
Hope someone has any ide whats wrong here.
Need to get this to work before this weekend that it when my girlfriend come home and kills me if this not working
aug-21 23:40:00 | RFXCOM Warning: | 36 (DeActivateReceiver) error receiver 1 not used! |
aug-21 23:39:19 | RFXCOM Warning: | 36 (RecRxChar) receiver #1 response was: FF, should be:2C, retry |
aug-21 23:17:27 | RFXCOM Warning: | 36 (DeActivateReceiver) error receiver 1 not used! |
aug-21 23:16:46 | RFXCOM Warning: | 36 (RecRxChar) receiver #1 response was: FF, should be:2C, retry |
aug-21 22:54:54 | RFXCOM Warning: | 36 (DeActivateReceiver) error receiver 1 not used! |
aug-21 22:54:54 | RFXCOM Warning: | 36 (RecRxChar) receiver #1 response was: FD, should be:2C, retry |
aug-21 22:32:21 | RFXCOM Warning: | 36 (DeActivateReceiver) error receiver 1 not used! |
aug-21 22:31:40 | RFXCOM Warning: | 36 (RecRxChar) receiver #1 response was: FD, should be:2C, retry |
aug-21 22:09:48 | RFXCOM Warning: | 36 (DeActivateReceiver) error receiver 1 not used! |
aug-21 22:09:48 | RFXCOM Warning: | 36 (RecRxChar) receiver #1 response was: FF, should be:2C, retry |
aug-21 21:47:15 | RFXCOM Warning: | 36 (DeActivateReceiver) error receiver 1 not used! |
aug-21 21:46:34 | RFXCOM Warning: | 36 (RecRxChar) receiver #1 response was: FD, should be:2C, retry |
aug-21 21:47:15 | RFXCOM Error: | 36 (CheckReceivers) receiver #1 RecRxChar returned an error. |
aug-21 21:47:15 | RFXCOM Error: | 36 (Reconnect) receiver #1 stopped due to comm failure, try to reconnect. |
aug-21 21:47:15 | RFXCOM Error: | 36 (RecRxChar) rec#1 didn't respond correctly to a set Variable Length Mode |
