I have purchased a RFXrtx433E with the intention of using it to control my Somfy indoor RTS blinds, of which I have about 17, hardwired to the house with no wall switches to turn them on and off.
On looking at how to get the Somfy blinds connected to the RFXrtx433E, I note that the RFXrtx433E instructions say that when connecting the RFXrtx433E to Somfy RTS, you need to:
This is extremely difficult to do with my layout - it involves removing the blinds, getting the wire feeds out of the walls, and disconnecting them, which would take hours and a couple of people and some very long ladders as some are 15 feet or more high in some locations.
Has anyone been successful in pairing Somfy RTS blinds to the RFXrtx433E without disconnecting power to all the other non-target blinds? I'm not quite sure why doing so should be necessary, as you only put one into the setup mode at any time, but I maybe I am missing something.
Thanks in advance.
Dave
"Disconnect power from all Somfy devices except the device to pair"
Thanks in advance.
Dave
