Hi There,
I picked up an RFXTRX433E, it's hooked up to Windows10 and I've flashed it to the Pro1 1041 firmware. I've got a couple of devices which have 433mhz remotes, a Neff I99CM67N0B cooker hood and a Knightsbridge IP663G Outdoor Remote Switch Box.
I dropeed a note to the RFXTRX.com guys and they advised that my firmware should be able to receive and transmit raw data.
I can press the remote and capture the raw data on the undefined channels and can create the text file to transmit the signal ok but I'm not getting the devices to respond.
i see that repeated buttons generate different sequences of numbers, does this signify a rolling code? Not sure how to proceed here.
I believe these remotes need to be paired with the devices, is there a method of pairing the rfxtrx433e to multiple devices?
