Dear Bert
going from HS3 Windows to HS3 ZEE S2 (just received it)
RFXCOM that works with HS3 windows can't start on ZEES2 here is the log message
Nov-23 17:27:00 Plug-In Finished initializing plug-in RFXCOM
Nov-23 17:27:00 Starting Plug-In RFXCOM loaded in 2102 milliseconds
Nov-23 17:27:00 Info Plugin RFXCOM with instance: has disconnected
Nov-23 17:27:00 RFXCOM start shutdown
Nov-23 17:27:00 Error Initializing plug-in(1): RFXCOM Instance::Error on InitIO: /usr/local/HomeSeer/html/images/RFXCOM/Alarm.gif does not exist Time to load: 716 milliseconds
Nov-23 17:27:00 RFXCOM Error: 40 (InitIO) error :System.IO.FileNotFoundException: /usr/local/HomeSeer/html/images/RFXCOM/Alarm.gif does not exist File name: '/usr/local/HomeSeer/html/images/RFXCOM/Alarm.gif' at System.IO.File.Copy (System.String sourceFileName, System.String destFileName, System.Boolean overwrite) [0x000b6] in <51aae36473e7439cb14534b3d8714641>:0 at System.IO.File.Copy (System.String sourceFileName, System.String destFileName) [0x00000] in <51aae36473e7439cb14534b3d8714641>:0 at HSPI_RFXCOM.utils.SetLanguage (System.String sLanguage) [0x000fd] in :0 at HSPI_RFXCOM.HSPI.InitIO (System.String port) [0x00aef] in :0
Nov-23 17:26:59 RFXCOM (InitIO) image path =/usr/local/HomeSeer/html/images/RFXCOM/
Nov-23 17:26:59 Starting Plug-In Initializing plugin RFXCOM ...
Nov-23 17:26:59 Info Plugin RFXCOM has connected. IP:127.0.0.1:46028
My Config
Current Date/Time: 23/11/2019 17:59:54
HomeSeer Version: HS3 ZEE S2 Edition 3.0.0.548
Linux version: Linux HomeTrollerZeeS2V6 4.9.35-v7+ #1014 SMP Fri Jun 30 14:47:43 BST 2017 armv7l GNU/Linux System Uptime: 0 Days 0 Hours 51 Minutes 2 Seconds
IP Address: 192.168.0.50
Number of Devices: 13
Number of Events: 19
Available Threads: 399
HSTouch Enabled: True
Event Threads: 0
Event Trigger Eval Queue: 0
Device Exec Queue: 0
HSTouch Event Queue: 0
Email Send Queue: 0
Enabled Plug-Ins
3.0.0.5: CM15A
3.0.1.7: HSZigBee
30.0.0.40: RFXCOM
3.0.1.252: Z-Wave
Contacted homseer support and they directly forward me to ypu ;o)))
Can you help Me ?
Regards Gilles
My Config
Event Threads: 0
Email Send Queue: 0
Enabled Plug-Ins
3.0.0.5: CM15A
3.0.1.7: HSZigBee
30.0.0.40: RFXCOM
3.0.1.252: Z-Wave
Can you help Me ?
Regards Gilles
