So I have a cheap electric projector screen with a 433mhz remote, I use RFXCom for a few devices, primarily Lightwave RF dimmers but I have also managed to read the code and create the output devices by pushing the buttons on my projector screen remote and then copying across the ID Code.
The thing is though I have 3 buttons (Up, Stop and Down) on the remote and I have created 3 devices in HS3 with each of them having a slightly different ID Code under the RFXCOM so I have
And for each of them I have similar to below (the ID code is obviously different for each)
My question is, is there a way to combine these into one HS3 device, I have tried creating a new output device and I can add the 3 values but I cannot find a way to set each value to send a different ID code (if that makes sense).
I considered linking devices but not sure this is what I want and I think this is limited to 2 devices anyway.
Any suggestions appreciated.
Thanks.
Thanks.
