I recently moved my HS3 setup from a Windows & server to a new server running Windows 10. The RFXCOM plugin did not like the move. I am using an RFXtrx433E USB. I plugged this into the Windows 10 unit. I moved my entire HS3 directory over from the old machine and everything else is working.
Since it has been years since I setup the RFXCOM system I have no recollection of what needs to be done.
I am getting communication failure from my wireless temp sensor and my Somfy blind is not responding
I turned on debug and here are some of the things I see:
Jan-12 10:44:18 RFXCOM 41 (TxData) COM19 data xmitted: 0D00000F02000000000000000000
Jan-12 10:44:18 RFXCOM Transceiver #1 alive check, seq# F
Jan-12 10:34:08 RFXCOM 41 (TxData) COM19 data xmitted: 0C1A0003010101010300000000
Jan-12 10:34:08 RFXCOM 41 (DeviceCmd) called with:X_TRX[1]Q:A:1:10101:54:_Down
Jan-12 10:34:08 RFXCOM 41 (DeviceCmd) called with dvref:167 cmd:_Down
Jan-12 10:34:08 RFXCOM 41 (ODevXmit) called with:167:_Down
Jan-12 10:34:08 Device Control Device: Kitchen RFXCOM Kitchen Blinds Control to Down (118) by/from: CAPI Control Handler
When I run RFXMngr and click connect it crashes. I don't see anything in RFXmngr to specify port, etc?
I realize this is not much to go on so please let me know what else I can post to help diagnose this. Thanks.
