Contacting HomeSeer This Week
See more
See less
Export RFXCOM HS2 devices to HS3
This is a sticky topic.
  • #16
    If a COM port is found and already used it will generate this system message. It is a warning message that can be ignored.
    • #17
      Ok, I usually start HS2 first so I guess that will occur each time HS3 is started. In the event that HS3 starts first for some reason, the Rfxcom plugin wont open any unused ports will it?
      Gary
      • #18
        The warning message appears only if you configure an RFXCOM receiver, transmitter, transceiver.
        If you open the RFXCOM device it will do a search for all available COM ports.
        • #19
          The Old HS2 updater only has up to version .18 where can I download the .22 version?
          James
          Running HS 3 on Win10 .
          • #20
            I can send you version .22 Contact support at rfxcom.com
            • #21
              Is there a way to move RFXCom devices from one install over to a new one (HS3->HS3)? Would really save me a lot of work instead of re-adding SOMFY RTS blinds.
              • #22
                All RFXCOM devices and associated data is stored in the HS3 database. Copy the database and it should operate
                • #23
                  Hmm..so if I only want the RFXCom devices, I can use SQL Browser to extract them?
