Have a problem and don't know if a SimpleRF or X10 plug-in solution.
I bought a couple of the X10 Security Motion Sensors which do not use standard X10 addresses. SimpleRF picks up the MS18 signal and ID code and creates a "SimpleRF Motion Sensor" on the Homeseer Device Management page. When motion is detected the new device turns ON, then OFF in a few seconds. However when I create an Event using the SimpleRF Motion Sensor device as a trigger, the Event does not run.
Checking the device configuration page, the X10 tab does not show, so the X10 plug-in does not know the device exits. I am guessing that could be why the event does not run, but I don't know how to fix. The X10 Plug-in does not allow me to create a MS18 Security device, only devices that use the standard X10 address code. Have not yet posted to the X10 Plug-in forum. Any insight appreciated.
