Error on install
  • Error on install
    C:\Program Files (x86)\HomeSeer HS3>hspi_simplerf.exe
    Plugin: SimpleRF, Instance: starting...
    Connecting to server at 127.0.0.1...
    Connected, waiting to be initialized...
    Initialized Version 1.0.0.3 of SimpleRF...
    Connection lost, exiting
    Error sending over stream: Unable to write data to the transport connection: Can
    not access a disposed object.
    Object name: 'System.Net.Sockets.Socket'..
    SimpleRF
    N/A 1.0.0.9 N/A Included
    WARNING: Failed getting InterfaceStatus from SimpleRF - the interface was not found in the list of active interfaces, the list may need to be refreshed.
    Jun-20 11:50:40 AM Error Initializing plug-in(2): SimpleRF Instance::Object reference not set to an instance of an object.STACK: at System.Runtime.Remoting.Messaging.LogicalCallContext.Propaga teIncomingHeadersToCallContext(IMessage msg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.InitIO(String port) at Scheduler.clsHSPI.CheckInterfaces()
    Jun-20 11:50:40 AM Info Plugin SimpleRF with instance: has disconnected
    Jun-20 11:50:40 AM SimpleRF init Initializing Version 1.0.0.3 of SimpleRF...
    Jun-20 11:50:40 AM Info Plugin SimpleRF has connected. IP:127.0.0.1:50368
    Jun-20 11:50:19 AM Info Plugin SimpleRF with instance: has disconnected
    Jun-20 11:50:19 AM Error Initializing plug-in(1): SimpleRF Instance::Plugin is not registered. Please obtain a valid license or trial.
    Jun-20 11:50:19 AM SimpleRF init Initializing Version 1.0.0.3 of SimpleRF...
    Jun-20 11:50:18 AM Info Plugin SimpleRF has connected. IP:127.0.0.1:50355
    Jun-20 11:49:44 AM Updater Install/Update of package SimpleRF was successful.
    Jun-20 11:49:44 AM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\HSPI_SimpleRF.exe
    Jun-20 11:49:43 AM Updater Installing package SimpleRF
    Jun-20 11:49:43 AM Updater Update HSPI_SimpleRF.exe downloaded successfully
    Jun-20 11:49:43 AM Updater Downloading update: SimpleRF
    Jun-20 11:49:43 AM Updater Starting download of updates
    Jun-20 11:46:43 AM Info Plugin SimpleRF with instance: has disconnected
    Jun-20 11:46:43 AM Error Initializing plug-in(1): SimpleRF Instance::Plugin is not registered. Please obtain a valid license or trial.
    Jun-20 11:46:43 AM SimpleRF init Initializing Version 1.0.0.3 of SimpleRF...
    Jun-20 11:46:43 AM Info Plugin SimpleRF has connected. IP:127.0.0.1:50109
    Jun-20 11:46:34 AM Plug-In Finished initializing plug-in SimpleRF
    Jun-20 11:46:31 AM Info Plugin SimpleRF with instance: has disconnected
    Jun-20 11:46:31 AM Error Initializing plug-in(1): SimpleRF Instance::Plugin is not registered. Please obtain a valid license or trial.
    Jun-20 11:46:31 AM SimpleRF init Initializing Version 1.0.0.3 of SimpleRF...
    Jun-20 11:46:31 AM Info Plugin SimpleRF has connected. IP:127.0.0.1:50069
    Jun-20 11:45:58 AM Info Plugin SimpleRF with instance: has disconnected
    Jun-20 11:45:58 AM Error Initializing plug-in(1): SimpleRF Instance::Plugin is not registered. Please obtain a valid license or trial.
    Jun-20 11:43:49 AM Error Initializing plug-in(2): SimpleRF Instance::Object reference not set to an instance of an object.STACK: at System.Runtime.Remoting.Messaging.LogicalCallContext.Propaga teIncomingHeadersToCallContext(IMessage msg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.InitIO(String port) at Scheduler.clsHSPI.CheckInterfaces()
    Jun-20 11:43:49 AM Info Plugin SimpleRF with instance: has disconnected
    Jun-20 11:43:49 AM SimpleRF init Initializing Version 1.0.0.3 of SimpleRF...
    Jun-20 11:43:48 AM Info Plugin SimpleRF has connected. IP:127.0.0.1:49960
    Jun-20 11:42:01 AM Plug-In Finished initializing plug-in SimpleRF
    Jun-20 11:41:58 AM Info Plugin SimpleRF with instance: has disconnected
    Jun-20 11:41:58 AM Error Initializing plug-in(1): SimpleRF Instance::Plugin is not registered. Please obtain a valid license or trial.
    Jun-20 11:41:58 AM SimpleRF init Initializing Version 1.0.0.3 of SimpleRF...
    Jun-20 11:41:57 AM Info Plugin SimpleRF has connected. IP:127.0.0.1:49852
    Any Ideas ?
    Sorry for the long delay, just got back in town. I'm looking into it now.
      OK, I fixed the problem. It was a bug in the code that was left-over from when the plugin wasn't free. I have it fixed and I'll submit the new version to HS to include on the updater. In the mean time, I uploaded it to OneDrive if anyone wants to download it this weekend. If you do download it please let me know if it works for you. Just stop the plugin, replace the file in your "C:\Program Files (x86)\HomeSeer HS3" (or wherever your HS3 installation directory is located), and restart the plugin.
      http://1drv.ms/1SRj3Hn
      Thanks!
      -Chris
        Excellent !
        Thanks Chris !
        it's working now (so far)
        Let you know of any issues.
