HomeSeer Message Board
HomeSeer Message Board (http://board.homeseer.com/index.php)
-   HomeSeer Current Cost Envi Plug-in (http://board.homeseer.com/forumdisplay.php?f=1043)
-   -   issue of charts (http://board.homeseer.com/showthread.php?t=188868)
RenderCAD May 9th, 2017 08:55 AM
issue of charts
2 Attachment(s)
Hello,
I would see the charts in HS3 about two values of energy monitoring . My customer has a photovoltaic system and he uses the first channel to read the energy Production and the second channel to read the Energy consumption. In this way he can see and to automatize when is the time to do work his home appliances. In the HS3Pro the values are correct but in the part dedicated to the chart we have the issue. In the drop down menu there is no device matching the values like you can see in the attached. How can I do to to insert these two values in the charts?
Massimo-RenderCAD
Simonk May 9th, 2017 10:05 AM
Originally Posted by RenderCAD (Post 1305536)
Hello,
Massimo-RenderCAD
I have mine set up the same, although the other way round i.e. channel 1 is consumption and channel 2 production.
I don't use the graphs in HS3, instead I just export current readings every five minutes to pvoutput.org.
RenderCAD May 16th, 2017 06:31 AM
issue of charts
Thanks Simonk
Ho saw that website and I believe It is very interesting and probability I'll say at my customer to do the registration on pvoutput.org. but I'd like resolve the issue also inside the HS3PRO because I'am sure that this is possible infact in another pc with the same software the device list is more long and these values are also included. I'don't know in which way is possible to include these values (devices) in the charts.
Massimo-RenderCAD
