Hello,
I am trying to get the Ardunio to read the input of a DHT11 (temp & humidity). There are some forum subjects on it already, so I did the best I could to duplicate them. I will be the first to admit, I am not a programmer. So, I set up everything, the Arduino w/ Ethernet has no problem connecting to HomeSeer, the Keep Alive log outputs scroll continuously by, but I never get any readings back from the DHT11. To me, it appears that the sketch program never falls into the loop to actually read the measurements. I have tried to alter the "if" conditions so that the loops are accessed, but, nothing. I have attached screenshots, log output, the sketch file for reference. At this point, I am not sure if it is some hardware issue, wrong libraries, or what.
I have HS3 running on a Pi w/ Raspian, the 147 version of the Arduino plugin. the signal pin of the DHT11 is an input on A0, and I think the values should be displayed in Input 3 and 4 of the devices. If someone has 5 minutes to take a look and tell me what noob thing I am overlooking, I would appreciate it. Also, what sketch command can I use to write a line to the log? That would help a lot to determine what is going on with the program.
David
David
