Tracker Plugin for HS3
    The Tracker Plugin allows you to track vehicle gas purchases, mpg, and maintenance
    For Maintenance you can enter how many miles between reminders and how many miles before to start reminding you.
    Ex. You could enter 5000 miles between oil changes. Then set to be reminded 500 miles early. So at 4500 miles you would start getting a reminder each time you enter a gas purchase.
    You can also track cost and usage for any item type that you enter. Electrical, gas, water, satellite tv, etc.
    Jeff Farmer
    HS 3, HSPhone
    1.0.0.2 is in the updater.
    1.0.0.2
    Fixed issue where a device was created for a vehicle even if you selected No on the edit form.
    Fixed issue where the Navigation tabs were not aligning up correctly.
    Jeff Farmer
    HS 3, HSPhone
