HomeSeer Message Board
HomeSeer Message Board (http://board.homeseer.com/index.php)
-   RFXCOM Plug-In (3P) (http://board.homeseer.com/forumdisplay.php?f=899)
-   -   Dooya Blinds ALL (http://board.homeseer.com/showthread.php?t=183477)
brientim August 21st, 2016 11:10 PM
Dooya Blinds ALL
3 Attachment(s)
Hello,
I am trying to create a Master Switch for Dooya Blinds. The Master Switch can control all channels and is achievable per the attached in RFXTrx as per screen shots.
The current implementation requires the Device Code and Id Code to be within the range and all zeros is not allowed
Is this achievable of do I need to create an Event and add individually.
b_weijenberg August 22nd, 2016 08:13 AM
You can create 1 device with a different ID and add this in all motors.
But the status is not correct now for each individual motor device. Maybe better to use a script and transmit the command to each motor.
brientim August 22nd, 2016 10:17 PM
Thanks for response and I was trying to avoid adding additional codes but to be honest, I have to for zone control anyway. I have just been a little lazy in doing so.
RenderCAD April 21st, 2017 11:04 AM
1 Attachment(s)
Hello
I am very interested to integrate system for Dooya Blinds with HomeSeer for my customer, I saw that you used the plugin RFXCOM but I'd like know if it need add also other particular code of programming.
Massimo-RenderCAD
____________________
Current Date/Time: 21/04/2017 17:03:01
HomeSeer Version: HS3 Pro Edition 3.0.0.318
Operating System: Microsoft Windows 7 Professional - Work Station
b_weijenberg April 21st, 2017 11:29 AM
1 Attachment(s)
You don't need any additional programming, the Dooya motor is controlled by the plugin.
RenderCAD April 21st, 2017 01:24 PM
Sorry
this plugin can manage also the partial opening, if I had to open the blinds at 20% can I do it?
Massimo - RenderCAD
b_weijenberg April 22nd, 2017 03:22 AM
As far as I known Dooya motors do not have an stop position.
Measure the time for a full open.
Use an event with a timer with a value of 20% of the full open time.
Transmit open, wait for this 20% time, transmit stop
