UltraLog and SQL 2000
    What is the steps for switching from access to MS SQL 2000
    Do I need to create the database and tables manualy?
    Try this:
    http://automatedhomeonline.com/HomeS...ftSQL2005.html
      I can't get the script to work on my SQL 2000 i get error on line 7 and ......
      Should it work on SQL 2000?
        Try this:
        PHP Code:
        /****** Object:  Table [dbo].[tblLog]    Script Date: 8/1/2005 8:47:52 AM ******/
        CREATE TABLE [dbo].[tblLog] (
        ID] [intIDENTITY (11NOT NULL ,
        Log_Date] [datetimeNOT NULL ,
        Log_Type] [varchar] (50COLLATE SQL_Latin1_General_CP1_CI_AS NOT NULL ,
        Log_Data] [varchar] (255COLLATE SQL_Latin1_General_CP1_CI_AS NOT NULL
        ON [PRIMARY]
        GO
        /****** Object:  Table [dbo].[tblSyslog]    Script Date: 8/1/2005 8:47:52 AM ******/
        CREATE TABLE [dbo].[tblSyslog] (
        Syslog_Date] [datetimeNOT NULL ,
        Syslog_Facility] [intNOT NULL ,
        Syslog_Severity] [intNOT NULL ,
        Syslog_Hostname] [varchar] (50COLLATE SQL_Latin1_General_CP1_CI_AS NULL ,
        Syslog_Msg_Tag] [varchar] (32COLLATE SQL_Latin1_General_CP1_CI_AS NULL ,
        Syslog_Msg_Content] [varchar] (1024COLLATE SQL_Latin1_General_CP1_CI_AS NOT NULL
        ON [PRIMARY]
        GO
        /****** Object:  Table [dbo].[tblSyslogFacility]    Script Date: 8/1/2005 8:47:53 AM ******/
        CREATE TABLE [dbo].[tblSyslogFacility] (
        Facility_Code] [intNOT NULL ,
        Facility_Description] [nvarchar] (255COLLATE SQL_Latin1_General_CP1_CI_AS NOT NULL
        ON [PRIMARY]
        GO
        /****** Object:  Table [dbo].[tblSyslogSeverity]    Script Date: 8/1/2005 8:47:53 AM ******/
        CREATE TABLE [dbo].[tblSyslogSeverity] (
        Severity_Code] [intNOT NULL ,
        Severity_Desc_Short] [nvarchar] (50COLLATE SQL_Latin1_General_CP1_CI_AS NULL ,
        Severity_Desc_Long] [nvarchar] (255COLLATE SQL_Latin1_General_CP1_CI_AS NOT NULL
        ON [PRIMARY]
        GO
        /****** Object:  Table [dbo].[tblTemperature]    Script Date: 8/1/2005 8:47:53 AM ******/
        CREATE TABLE [dbo].[tblTemperature] (
        Temp_Date] [datetimeNOT NULL ,
        Temp_Device] [varchar] (3COLLATE SQL_Latin1_General_CP1_CI_AS NOT NULL ,
        Temp_Value] [numeric](100NOT NULL
        ON [PRIMARY]
        GO
          Many thanks works perfect with the last script.
            THis worked for me too...
            im up and running on SQL2000 now....
            ~Jeff
              It appears the Microsoft SQL 2005 SP2 needs HOSTNAME\INSTANCE for the Data Source instead of just localhost.
              Example:
              Provider=SQLOLEDB;Data Source=MEDIACENTER\SQLEXPRESS;Initial Catalog=HomeSeerDB;Trusted_Connection=yes
                Example:
                because I had 3 versions installed (SQL2000 SP3, SQL2005 Express, SQL2008 CT), then uninstalled them all...
                now when I setup I have to use localhost vs the actual server name..weird...
                what are the benefits of sql 2005 express over sql 2000?
                  I'd like some assistance if anyone can help. I'm running SQL Express 2008, I've created a database and run the above script to create the tables, UltraLog thinks it's connected to the SQL server (and I see a valid authentication entry in my log) but I still get no entries, and the UltraLog status page just shows 0 Inserts and 300+ failures.
                  Any ideas on how to to troubleshoot further would be much appreciated.
                  ----- Fixed -----
                  I had a database permissions error, my HomeSeer user did not have sufficient rights to write to the database. All up and running with SQL.
                  Author of Highpeak Plugins | SMS-Gateway Plugin | Blue Iris Plugin | Paradox (Beta) Plugin | Modbus Plugin | Yamaha Plugin
                    UltraJones, do you have the SQL scripts to create the tables for logging device status and device value changes too please? When I try and enable these features I get errors consistent with the tables not being in my SQL Database
                      Bump. UJ - any advice on creating the tables for device status and value changes?
                        Here are the create table statement generated by SQL 2008:
                        PHP Code:
                        USE [HomeSeerDB]
                        GO
                        /****** Object:  Table [dbo].[tblDeviceStatusLog]    Script Date: 07/30/2009 19:42:22 ******/
                        SET ANSI_NULLS ON
                        GO
                        SET QUOTED_IDENTIFIER ON
                        GO
                        SET ANSI_PADDING ON
                        GO
                        CREATE TABLE
                        [dbo].[tblDeviceStatusLog](
                        id] [intIDENTITY(1,1NOT NULL,
                        ts] [datetimeNULL,
                        hc] [char](1NOT NULL,
                        dc] [varchar](3NOT NULL,
                        status] [intNOT NULL,
                        data1] [intNULL,
                        data2] [intNULL,
                        CONSTRAINT [pkID2PRIMARY KEY CLUSTERED
                        idASC
                        )WITH (PAD_INDEX  OFFSTATISTICS_NORECOMPUTE  OFFIGNORE_DUP_KEY OFFALLOW_ROW_LOCKS  ONALLOW_PAGE_LOCKS  ONON [PRIMARY]
                        ON [PRIMARY]
                        GO
                        SET ANSI_PADDING OFF
                        GO
                        PHP Code:
                        USE [HomeSeerDB]
                        GO
                        /****** Object:  Table [dbo].[tblDeviceValueLog]    Script Date: 07/30/2009 19:44:10 ******/
                        SET ANSI_NULLS ON
                        GO
                        GO
                        SET ANSI_PADDING ON
                        GO
                        CREATE TABLE
                        [dbo].[tblDeviceValueLog](
                        ts] [datetimeNULL,
                        data1] [intNOT NULL,
                        data2] [intNOT NULL,
                        CONSTRAINT [pkID1PRIMARY KEY CLUSTERED
                        idASC
                        ON [PRIMARY]
                        GO
                        GO
                          Is there a new create statement for the syslog tabels for SQL 2008? As I am getting lots of syslog insert errors?
                          Darren
                            The ones listed above should work. Can you send me the create table statements so I can review them? Please send them to ultrajones@hotmail.com.
                            Ultrajones
                              Sql 2012
                              I have tried using these scripts on SQL 2012 but they don't seem to work. Has anyone got any updated DB creation scripts for SQL 2012?
                              Darren
