Strange error duplicate name in InpAddrDvref
    On booting up my HS3 system I have this error in the startup HS4 popup, and I am not sure what to do about it and what it means...
    08/09/2017 16:21:55 ~!~RFXCOM Error: ~!~35 (InitVariables) duplicate name in InpAddrDvref:TH1[48132]T
    I think TH1[48132]T is a temperature sensor, I think it is a newly created one after a battery change
    It seems there are 2 devices in the HS database with same ID.
    Remove 1 device which is not used from the database.
      What do you mean by database ? I had a look in the RFXCOM Input devices table, and 48132 is only once in there, so I guess the database is not that ?
        It is the Homeseer .hsd database which is in the HS Data directory. Check the Devices.
        Or try this:
        Stop the RFXCOM plug-in and delete the device TH1[48132]T.
        Start the plugin and check if the other TH1[48132]T device is present.
          Problem solved. Somehow 2 devices used 48132T, no idea how it happened, but I managed to correct it, and the error has gone.
