I have an issue with Get Zone Info with my panel that has persisted from HS2 into HS3. I have named all of the zones in DL900. But when I try to read them into HS3 only some of them come through. When I check in DL900 and read the section, they show fine. By reading other posts I see I that I can edit the ini file and update them manually - but I thought I would check in before I do that to see if there is any other advice. Thanks.
Some zone names not reading from panel
Originally posted by simonmason View PostI have an issue with Get Zone Info with my panel that has persisted from HS2 into HS3. I have named all of the zones in DL900. But when I try to read them into HS3 only some of them come through. When I check in DL900 and read the section, they show fine. By reading other posts I see I that I can edit the ini file and update them manually - but I thought I would check in before I do that to see if there is any other advice. Thanks.Regards,
Rien du Pre
The Netherlands
Using:
Plugin's:
RFXCOM, mcsMQTT, Z-Wave
I just ran into this with the DL900 software to. I believe it depends where you name the zones in the software. If you name them under the main panel, they don't seem to carry over. If you name them under the second item down on the Expander menu, it works.
I think it has to do with naming the zones for the LCD keypad display vs the reporting zone fields. Not entirely sure about that one. But it seems to work. The same as if you manually named the zones via *92 on the keypad.-Tim
HSPro - 3.XXX - Dell mini W7 x32
Way2 Call
Elk M1 Gold
UPB HAI switches
HAI RC2000 Thermostat
