The mcsMusic plugin full package is available from the Updater. Selective updates will be made to the plugin based upon user request and feedback. These interim updates will be logged and posted in this thread.
The zip file contents contains the paths relative to the homeseer root. If unzipped into the homeseer root then the files should be stored in the correct folders. Homeseer cannot be running when the files are extracted.
<pre class="ip-ubbcode-code-pre">
ID Version Description
PR1 1.0.5 Get Lyrics / Get Bio dont work
PR2 1.0.5 Allow multiple copies of same player on same computer
PR3 obe Allow path for remote operations to be explicitly specified
PR4 1.0.7 Allow local-only file path operations
PR5 1.0.7 Allow shared drive for HS computer to be explicitly specified
PR6 1.1.0 Add WMP Support
PR7 1.2.0 Bio download not working
PR8 1.2.0 Allow import of individual mp3 tracks to library & database
PR9 1.2.0 Slinkx.ocx loads when CDJ not selected
PR10 1.2.1 Database entries are deleted for CD-only records
PR11 Genre playlists are not built
PR12 1.3.5 SliMP3 support
PR13 1.3.5 WMP Playlist item selection offset by 1
PR14 1.3.5 Javascript error on single quote titles
PR15 1.3.5 Improve recogniztion of tracks between player and database
PR16 1.3.5 Add global variables for player-related objects
PR17 1.4.0 Enable clientIP-based screen sizing
PR18 1.4.0 Allow user-selectable spec for number of player of each type
PR19 1.4.1 Support multiple SliMP3
PR20 1.4.1 Default sizing for larger screens not available
PR21 1.4.3 Allow multiple players on same remote computer
PR22 1.4.3 Handle case of player shutdown on remote via script
PR23 1.4.3 Hidden Frame Overflow
PR24 1.4.3 Immediate feedback for change of player selections
PR25 PopulateGenre Key already associated error
PR26 BuildcdjPages Permission Denied error
PR27 1.5.0 Allow multiple players on same remote computer
PR28 1.6.0 Add support for 4-tier library
PR29 1.6.1 Allow pointer files for multiple path libraries
PR30 1.6.2 Tracks Database table may not have Artist or SoundFile
PR31 1.6.3 Progress Info on ProcessASP error
PR32 1.6.5 Extend Level 1 Access to Tax day
PR33 1.6.7 Local folders not created for WMP w/o exe
PR34 1.6.9 Restart client WMP is status shows not loaded
PR35 1.6.9 Add button to treminate WMP clients
PR36 1.7.0 Add support for flat library structure
PR37 1.7.0 ID3 reconcille into database problems
PR38 1.7.0 Remote Player does not launch
PR39 1.7.0 arrSpeaker typo in mcsMusicPlayer.txt
PR40 1.7.0 awake/sleep logic problems
PR41 1.7.1 Slinkx does not load on LoadPlayer script command
PR42 1.7.2 Loose control of WMP on Stop button
PR43 1.7.2 Extend trial period
PR44 1.7.2A AddFile error on building library
PR45 1.7.2A Names with \,/ etc cause folder creation problems
PR46 1.8.0 Add property PlaylistIndex for scripting access
PR47 1.9.0 Add status change on playlist device for track changes
PR48 n/a Powered.jpg not showing in Album picker page (tail.htm edit)
PR49 1.9.2 Expode/Condense not working
PR50 1.9.2 First playlist pulldown cannot be selected on initial draw
PR51 1.9.3 Event of playlist device always selects last played playlist
---- Above From Updater
PR52 1.9.4 Device Action on Player status provides incorrect options
PR53 1.9.5 Player 1 always defaults to CDJ on playlist devices
PR54 1.9.6 HS Devices only update when now playing browser is open
PR55 1.9.8 LoadRemotePlayers error
PR56 1.10.0 HS2 Compatibility
PR57 1.10.2 Remove license requirement
</pre>
Note that the updates are contained in multiple zip files. In general the full set of files need to be downloaded to assure consistentency among the components. Also note that the mcsMusicPlayer.txt file will overwrite your customized file of the same name. Protect your file prior to unzipping.
</pre>
