The baseline mcsMovement package is available from the updater. The most current updates will be maintained here.
<pre class="ip-ubbcode-code-pre">
PR1 1.3.0 Syncronize Associated Areas at startup
PR2 1.3.0 Change Event Sensor Type to Toggle Type
PR3 1.3.2 Provide ExecX10, SetDeviceStatus, SetDeviceValue methods
PR4 1.3.4 Data Folder does not exist
PR5 1.3.5 Error code 91 at shutdown
PR6 1.3.5 Browser Title bar contains HTML tags
PR7 1.3.5 Background color cannot be changed
PR8 1.3.5 Time field results in movement.asp abort
PR9 1.3.5 Title color option added
PR10 1.3.5 Future activity drawn as black rather than background in movement.asp
PR11 1.4.0 Default icons are not consistent
PR12 1.4.0 Add indivudual control for Elapsed Time string updates
PR13 1.4.0 Add exposed method to return ElapsedTime
PR14 1.4.0 Polarity of Display graphics not sensitive to Sensor Type setting
PR15 1.4.3 Movement triggers with only one end's status change
PR16 1.5.0 Add ability to store status changes in mcsTemperature for Line Charts
PR17 1.5.1 Dependency exists on load order/presence of mcsTemperature
PR18 1.5.3 No real change, just added some parens to assure correct logic
PR19 1.5.4 Transparent changes for xap integration
PR20 1.5.6 fail-safe tool tip on wrong text box
PR21 1.5.6 sync problems with hs status
PR22 1.5.8 Area Arm Device does not stick on setup page
PR23 1.5.9 Allow user to enter SQL Provider string
PR24 1.5.10 Area device does not change on second movement
PR25 1.5.11 Object Missing Error on Motion chart
PR26 1.8.0 xAP support for xapBSC schema
PR27 1.8.0 Support for Battery elapsed time
PR28 1.8.0 Support for Dimmable devices
PR29 1.9.0 HS2 Compatibility
PR30 1.9.1 HS2 hs.GetEvent obsolete
PR31 1.9.3 HS2 shutdown Movement Error Message Box
PR32 1.9.5 HS2 hs.GetDeviceRef / Long vs Integer
PR33 1.9.7 HS2 hs.NewDeviceRef operation
----------- Above in Updater --------------
PR34 1.9.10 Add HS Link for mcsMovement
PR35 1.10.0 Add script parameter support
PR36 1.10.1 Add info for duplicate device definitions
PR37 1.10.2 Remove info for duplicate device definitions
PR38 1.10.3 Error info for moving device from Managed to unmanaged
PR39 1.11.0 Add global override for icon and elapsed time string updates
PR40 1.11.0 Add hs.setdevicestatus AreaDC, 3 to turn OFF area device
PR41 1.11.2 Recompile
PR42 1.12.0 Add user selection of mins vs secs for managed devices
PR43 1.12.1 Script filename not visible on setup form
PR44 1.12.2 SetupValueTriggering 438 on line 60 error
PR45 1.12.3 Area device does not behave properly when ON-OFF sensor used
PR46 1.13.0 Remove cleanup of events with trigger scripts 'cause HS2 .scripts property removed
PR47 1.13.0 Added Value Change Event callback from HS
PR48 1.13.1 StatusChange line 70 overflow error
</pre>
Note that the HTML help file updates are located on the next message. It was too big to fit it into a single posting.
</pre>
