Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion
Lighting & Primary Technology Discussion Lighting & Primary Technology General Discussion
Old March 17th, 2012, 11:00 PM
kruane kruane is offline
Seer
CM 15 & Ninja ?
Was going to give Blade's Ninja control plugin a test spin, untill I discovered that his CM19 driver only worked under Windows 7 23-bit...unfortunately, my system is 64-bit, and I REALLY don't want to reformat and reinstall the 32-bit version.
That being said, the CM15 USB interface DOES transmit signals to the pan & tilt cameras.....however, only through the remote control...but does that not indicate that the CM15 is capable of accepting variables and sending them on the the pan & tilts ? ( Oh, and this works, with or without the CM19 attached).
Now, I used to use Case's CM19 USB plugin when I used Homeseer 1.x, along with his web-page interface. That doesn't work under Windows 7 & Homeseer 2.
So, I guess my question is....does anybody know if the CM15 plug-in accepts variables from programming, and if so, what would the syntax of those commands be ?
Old March 18th, 2012, 02:09 PM
Gogs's Avatar
Gogs Gogs is offline
OverSeer
I run Blade's Ninja Control under XP Pro and seem to remember having to download a seperate driver which was detailed in the docs.
A founder member of "The HA Pioneer Group" otherwise known as the "Old farts club!"
HomeSeer 3 V 3.0.0.318 with ALEXA (AKA Amazon Echo)
BL Radar V2.0.217; BLRF V2.0.85.0; HS Touch V3.0.0.1034 X10 V3.0.0.42; PHLocation V3.0.0.38; Zwave V3.0.1.110; X10 V3.0.0.42
BLBackup V2.0.39;ImperiHome3.0.0.20 All on Windows XP Pro
Old March 18th, 2012, 07:57 PM
Seer
Quote:
Yup, for 32-bit only.
Old March 20th, 2012, 02:38 PM
Gogs's Avatar
OverSeer
Try dropping Blade an email and see if he knows of any download you could get.
HTML code is Off
