Discussions related to HomeSeer Beta builds 3.0.0.369->3.0.0.423
    Don't think you want to release this version .393.
    Dec-10 2:47:36 PM Error Initializing plug-in(1): YAMAHA-RECEIVER Instance::Error on InitIO: Could not resolve field token 0x04000b79
    Dec-10 2:47:36 PM Info Plugin YAMAHA-RECEIVER has connected. IP:127.0.0.1:44748
    Dec-10 2:47:35 PM Plug-In Finished initializing plug-in Z-Wave
    Dec-10 2:47:35 PM Info Plugin Z-Wave with instance: has disconnected
    Dec-10 2:47:31 PM Z-Wave Finished: 79 Z-Wave Scenes, applying changes to the database...
    Dec-10 2:47:31 PM Z-Wave Finished processing Z-Wave Devices.
    Dec-10 2:47:30 PM Z-Wave Finished: 79 Z-Wave Devices, applying changes to database...
    Dec-10 2:47:30 PM Z-Wave Saving Z-Wave Devices Information...
    Dec-10 2:47:30 PM Z-Wave Finished processing Z-Wave Network(s).
    Dec-10 2:47:30 PM Z-Wave Finished: 1 Z-Wave Networks, applying changes to database...
    Dec-10 2:47:30 PM Z-Wave Saving Z-Wave Network Information...
    Dec-10 2:47:30 PM Error Initializing plug-in(1): Z-Wave Instance::Error registering web pages with the HomeSeer server.
    Dec-10 2:47:30 PM Z-Wave Finished: 79 Z-Wave Scenes, applying changes to the database...
    Dec-10 2:47:30 PM Z-Wave Finished processing Z-Wave Devices.
    Dec-10 2:47:29 PM Z-Wave 79 total Z-Wave Data Objects loaded.
    Dec-10 2:47:29 PM Z-Wave Network 003D0C95 has 79 device data elements.
    Dec-10 2:47:29 PM Z-Wave 1 Networks were restored from the data in the database... Building data connections.
    Dec-10 2:47:29 PM Z-Wave Loading Z-Wave Data Objects...
    Dec-10 2:47:27 PM Z-Wave 1 total Z-Wave Network Objects loaded.
    Dec-10 2:47:27 PM Z-Wave Loading Z-Wave Network Objects...
    Dec-10 2:47:25 PM Z-Wave Database: Opening (Mode=Read Only) up HomeSeer database /home/william/HomeSeer/Data/Z-Wave/Z-Wave2.db
    Dec-10 2:47:23 PM Z-Wave InitIO called, plug-in version 3.0.1.154 is being initialized...
    Dec-10 2:47:23 PM Z-Wave Note, Z-Wave send timeout is currently at 5000 seconds, which is not the default
    Dec-10 2:47:23 PM Info Plugin Z-Wave has connected. IP:127.0.0.1:44742
    Dec-10 2:47:23 PM Plug-In Finished initializing plug-in weatherXML
    Dec-10 2:47:19 PM Info Plugin weatherXML with instance: has disconnected
    Dec-10 2:47:19 PM Error Initializing plug-in(1): weatherXML Instance::Error on InitIO: Could not resolve field token 0x04000b79
    Dec-10 2:47:19 PM weatherXML Error InitIO: Could not resolve field token 0x04000b79
    Dec-10 2:47:18 PM Info Plugin weatherXML has connected. IP:127.0.0.1:44736
    Dec-10 2:47:18 PM Plug-In Finished initializing plug-in Ultra1Wire3
    Dec-10 2:47:14 PM Info Plugin Ultra1Wire3 has connected. IP:127.0.0.1:44732
    Dec-10 2:47:13 PM Plug-In Finished initializing plug-in Monoprice Amp
    Dec-10 2:47:13 PM Error Initializing plug-in(2): Monoprice Amp Instance::Object reference not set to an instance of an objectSTACK: at (wrapper managed-to-native) System.Object:__icall_wrapper_mono_remoting_wrapper (intptr,intptr) at (wrapper remoting-invoke) HomeSeerAPI.IPlugInAPI:InitIO (string) at Scheduler.clsHSPI.CheckInterfaces () <0x40535000 + 0x0028a> in :0
    Dec-10 2:47:13 PM Info Plugin Monoprice Amp with instance: has disconnected
    Dec-10 2:47:13 PM Info Plugin Monoprice Amp has connected. IP:127.0.0.1:44728
    Dec-10 2:47:13 PM Plug-In Finished initializing plug-in Kodi
    Dec-10 2:47:10 PM Info Plugin Kodi with instance: has disconnected
    Dec-10 2:47:10 PM Error Initializing plug-in(1): Kodi Instance::System.BadImageFormatException: Could not resolve field token 0x04000b79 File name: 'Scheduler' at Scheduler.PageBuilderAndMenu+clsPageBuilder..ctor (System.String pagename) <0x40415cc0 + 0x00a4f> in :0 at HSPI_Kodi.WebConfig..ctor (System.String pageName) <0x404153c0 + 0x00067> in :0 at HSPI_Kodi.KodiApp.Init () <0x40411f70 + 0x00243> in :0
    Dec-10 2:47:10 PM Kodi ERROR System.BadImageFormatException: Could not resolve field token 0x04000b79 File name: 'Scheduler' at Scheduler.PageBuilderAndMenu+clsPageBuilder..ctor (System.String pagename) <0x40415cc0 + 0x00a4f> in :0 at HSPI_Kodi.WebConfig..ctor (System.String pageName) <0x404153c0 + 0x00067> in :0 at HSPI_Kodi.KodiApp.Init () <0x40411f70 + 0x00243> in :0
    https://forums.homeseer.com/forum/de...plifier-plugin
      I moved over to the rock 64 with 4GB of memory running Ubuntu 16.04 64 bit. I combined everything into one system, no more remote plugins. I am leaving my second instance of HS3 on the dual RPi3 setup.
      So far the only issue is RFXCOM, which is generating warnings about the callback queue several times an hour. I am currently using it to monitor three Oregon temperature sensors, so I am contemplating just removing it and getting different sensors.
        I spoke to soon, it just crashed. I will install V393 and see how I get on.
        Greig.
        Sent from my SM-G950F using Tapatalk
        Scripts =
        Various
          What is the version of the Z-Wave plugin you are running?
          Can you make sure you are running with the latest Beta? I know there was an issue with some of the plugins that caused this recursive crash. However, I would not expect the crash to be in HS3 if this was the case, but I want to rule it out. The latest beta for sure does not have this issue. (at least not the one I know about)
          Greig.
            Rich,
            I was on V.390 with Z-Wave V3.0.1.160 and I have updated to V.393 with Z-wave V3.0.1.165 and will keep you posted with any problems.
            Greig.
            HomeSeer Version: HS3 Pro Edition 3.0.0.393
            Operating System: Microsoft Windows 7 Home Premium - Work Station
            System Uptime: 0 Days 2 Hours 11 Minutes 16 Seconds
            IP Address: 192.168.0.10
            Number of Devices: 964
            Number of Events: 362
            Available Threads: 400
            HSTouch Enabled: True
            Event Threads: 5
            Event Trigger Eval Queue: 0
            Device Exec Queue: 0
            HSTouch Event Queue: 0
            Email Send Queue: 0
            Anti Virus Installed: Norton Security
            Enabled Plug-Ins
            1.0.0.144: Arduino Plugin
            2.0.47.0: BLBackup
            2.0.40.0: BLGData
            2.0.93.0: BLRF
            2.0.70.0: BLSpeech
            0.0.0.42: Current Cost 3P
            3.6.5.0: Harmony Hub
            3.5.1118.14: HSBuddy
            3.0.1.9: Kodi
            3.0.1.109: PHLocation
            1.0.0.3: PowerOne
            1.0.0.1: Restore
            30.0.0.36: RFXCOM
            3.0.4.8: SDJ-Health
            3.0.1.165: Z-Wave
            Scripts =
            Various
              Where did you find a bootable image of Ubuntu 16.04 for the Rock 64?
              I got mine a several weeks ago and have yet to find ANY image of any Linux OS flavor that will boot successfully.
              -M.
                Here is a link for Ubuntu 16.04...on the Rock64.
                You write the image to a microSD card same as you would for writing an RPi Wheezy, Jessie or Stretch image.
                Xenial Mate
                Currently running 16.04 here on the Pine64 2Gb computer - over a year now...
                A bit off topic here are the specs for the Pine64...
                Pine64:~# uname -a
                Linux ICS-Pine64 3.10.105-bsp-1.2-ayufan-77 #1 SMP PREEMPT Sun Jul 9 12:09:30 UTC 2017 aarch64 aarch64 aarch64 GNU/Linux
                Pine64:~# lsb_release -a
                No LSB modules are available.
                Distributor ID: Ubuntu
                Description: Ubuntu 16.04.3 LTS
                Release: 16.04
                Codename: xenial
                Pine64:~# mono -V
                Mono JIT compiler version 5.4.1.6 (tarball Wed Nov 8 21:20:16 UTC 2017)
                Copyright (C) 2002-2014 Novell, Inc, Xamarin Inc and Contributors. www.mono-project.com
                TLS: __thread
                SIGSEGV: normal
                Notifications: epoll
                Architecture: arm64
                Pine64:~# lscpu
                Architecture: aarch64
                CPU(s): 4
                On-line CPU(s) list: 0-3
                Thread(s) per core: 1
                Core(s) per socket: 1
                Socket(s): 4
                CPU max MHz: 1344.0000
                CPU min MHz: 480.0000
                * ROCK64 1500 Mhz
                lshw -c memory
                *-memory
                description: System memory
                physical id: 5
                ROCK64 - 4GB 1600MHz LPDDR3 memory
                *-network:0
                description: Ethernet interface
                physical id: 5
                logical name: eth0
                serial: 55:55:55:55:55:55
                capacity: 1Gbit/s
                capabilities: Ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
                OS - microSD
                ROCK64 - OS - microSD or eMMC
                With the Rock64 4Gb you will be able to also run one lite Oracle MS VB for Speaker SAPI if you want.
                Auto mator
                  I have upgraded to .393 and notice a curious problem when I come to rename a device - I have recorded a video in case it makes it easier to explain but renaming a device causes the device code to drop out. I use the device code in the plugin to determine which device is controlled so it is pretty fatal to the plugin that this is erased.
                  https://www.youtube.com/watch?v=XvUKHbDoCmQ
                    I tried it here and I cannot get this to happen. Plugins have access to device addresses, is it possible one of your plugins is doing this? Can you disable all your plugins and see if it still happens?
                      I have disabled every plugin apart from the plugin that was creating these devices, still behaves the same.
                      I then disabled that plugin (leaving HS with no plugins running at all) and it still is behaving this way. I've tried running hs.saveeventsdevices and then trying and still is the same.
                      One thing odd I have noticed is that the plugin was connected remotely and in the interfaces page showed no detail - is that linked with anything??
                        Hi MrHappy,
                        Looking at the video, I see that the the address code is just "2". I believe that is an invalid address code, as it should have a letter and a number, like A2 or B24. If you open the device, I see the Code (the field above the address) is already empty, so on save it will probably use that to overwrite the invalid code.
                        Also, I think it is recommended to use the address field (and NOT the address code field) in plugins. If you set an address in a plugin, a user is unable to overwrite the field (perhaps only with a script) so it ensures it will never change by accident by a user.
                        stefxx
                          This info is correct. Try changing your codes to something with a letter and a number.
                          Originally posted by stefxx View Post
                          Hi MrHappy,
                            Hi MrHappy,
                            I was under the impression (and using the Z-Wave plugin as an example) that the address can be what you want (and in my case it is a UID of the light bulb that is programmed into it) then you can set the code again to what you want and in my case I set it to the device number which is not that different to how the Z-Wave plugin appears to work. So when I call hs.DeviceExistsAddressFull I can pass the address+code and get the reference fine.
                            I thought that setting this property on a plugin created device meant that a user couldn't edit it - see here at 39:20s
                            https://www.youtube.com/watch?v=1TjSOfARK4Y&t=39m20s
                            and even so shouldn't it be retained if all I do is go into the page and edit the name? I dare to change any other devices at the minute as I don't know the implication of it.
                              The address field cannot be changed by the user if set by a plugin. The code field can be changed always by the user. Therefor, I am only using the address part in my plugins.
                              The video is a bit confusion. I didn't see the whole video, but the code they use is "00E66A84-3-Q3". This means that "00E66A84-3" is the address, and "Q3" is the code. I guess you could do the same in your plugin, and you wouldn't need to rely on the code field anymore.
                              This hasn't change recently, so it probably has nothing to do with build 393.
                              stefxx
                                -M.
                                This is what I am running:
                                uname -a
                                Linux rock64 4.4.77-rockchip-ayufan-118 #1 SMP Thu Sep 14 21:59:24 UTC 2017 aarch64 aarch64 aarch64 GNU/Linux
                                lsb_release -a
                                Release: 16.04
                                Codename: xenial
                                mono --version
                                I got it from the ayufan github site (as referenced from the pine64 site) back around the beginning of October. It booted right up from SD no problem. I later copied it over to eMMC and that is working well also. I have not tried any of the newer releases. It seems to still be a work in progress, maybe I just got lucky.
                                Bill
