Go Back   HomeSeer Message Board > Camera Plug-ins > Camera Discussion > HomeSeer NetCam Plug-in
HomeSeer NetCam Plug-in The NetCam plugin provides access to network based cameras.
  #41
Old July 25th, 2011, 12:29 PM
Rupp's Avatar
Rupp Rupp is offline
OverSeer
Let me check with Rich on this dead link. He should be able to fix this.
-Rupp
  #42
Old July 25th, 2011, 01:48 PM
rjh's Avatar
rjh rjh is offline
HomeSeer Technologies
The original link to the update has been restored.
Quote:
Rich,
  #43
Old July 25th, 2011, 08:12 PM
Dafunktyfunk's Avatar
Dafunktyfunk Dafunktyfunk is offline
Seer Master
Oh man, I got all excited that a new version of the plug was available...
Transitioning to HS3Pro .298 - WinXPEmbedded
Hometroller S3 Pro - WinXPEmbedded - HSP 2.5.0.81 - BLStat - HSPhone - HSTouch Srvr 1.0.0.73 - Touchpad - BLLan - BLOccupied - DSC Plug 2.0.0.14 - BLStat .38
  #44
Old July 25th, 2011, 09:03 PM
huggy_d1's Avatar
huggy_d1 huggy_d1 is offline
Seer Master
Quote:
Yeah, me too. I was hoping for one with a nice public api
huggy_d1
Automating made easy
  #45
Old July 26th, 2011, 01:05 PM
Pete's Avatar
Pete Pete is online now
OverSeer
While not really public many of the functions are defined and not utilized with calls to the API in the Netcam ASPX files.
If you have a look at the very beginning of development you'll see references added to these calls in the API.
I'm thinking they are all there; just not utilized; it is though have to "reverse" engineer the plugin; which does kind of make it a bit more of a difficult endeavor.
The second edition tended to clean up some of what the first first version lacked; and then some.
Automator
Hardware | HS3 Pro - Haswell iSeries 3 - 16Gb | HS3 Lite Pine64 2Gb computers
HS3 Pro & Lite
Edition Beta 3.0.0.398 | Ubuntu 16.04 64 bit | Oracle Windows Virtual Box ==> for Wintel only SAPI and HS3 plugins
HS3 Plugins - a bunch
Light switches - X10,UPB, ZWave and Zigbee
Speech - Microsoft SAPI - Amazon Echo
Security - Leviton Omni Pro 2
Weather - Davis Vantage Vue - MeteoStick
Firewall - PFSense
CCTV - Zoneminder
  #46
Old August 30th, 2011, 08:55 AM
Wadenut's Avatar
Wadenut Wadenut is offline
OverSeer
The plugin works well with one minor exception. It seems that if any one camera happens to have dropped offline the Netcam View page will fail to load. If this could be fixed, this would be a fine plugin.
  #47
Old August 30th, 2011, 05:35 PM
Pete's Avatar
OverSeer
Yeah sometimes I use the ini file to make adjustments.
  #48
Old August 30th, 2011, 06:38 PM
Wadenut's Avatar
OverSeer
Quote:
Yup. Sometimes that's the only way possible when the page refuses to load. Surely the plugin could test for a response and ignore offline cameras.
  #49
Old August 30th, 2011, 07:07 PM
Pete's Avatar
OverSeer
I don't really use it that much anymore. Its kind of slow.
I have multiple events which do the following. I don't really pay too much attention to the speed though.
Netcam is still doing its thing and getting pictures; I just don't use the GUI to look at them.
Quote:
Dim S As Object = hs.GetURLImage ("http://www.xxx.yyy.zzz","/cgi-bin/nph-zms?mode=single&monitor=12&scale=100&user=username&pass=user password",false,80,"html/images/wunderground/image3.jpg")
  #50
Old August 30th, 2011, 08:51 PM
huggy_d1's Avatar
Seer Master
Ok, I took Pete's advise and came up with this as a starting point for an API to the netcam plugin.
Netcam Plug-In
----- best guesses at API after a few minutes in the netcam .aspx files -----
pi.GetCams()
    returns list of cameras which can be parsed with the following code
            For i As Integer = 0 To Cams.Count - 1
                Dim configparts() As String = Split(Cams(i).ToString, ",")
                lstCameras.Items.Add(configparts(0) & " - " & configparts(1))
            Next
pi.MaxPics : CInt
    sets / gets configuration setting for maximum # of pictures for each camera
pi.Columns : CInt
    sets / gets configuration setting for # of columns to display camera images
pi.Rows : CInt
    sets / gets configuration setting for # of rows to display camera images
pi.name()
    sets / gets camera name
pi.DeleteCam(strCameraName)
    deletes camera, takes camera name as string
pi.ValidateCamName(Me.txtNewName.Text)
    validated camera name before deleting, takes text for new camera's name
pi.addcam(Me.txtNewName.Text, Me.txtNewURL.Text)
    adds new camera and associated URL, takes camera name and URL as text
pi.getimages(strCameraName)
    returns collection of files (Dim files As Collection)
pi.UpdateInternalPictureCollection()
    Updates picture collection after deleting images
pi.EnqueuePictureRequest(strCameraName)
    Add request for new picture to Queue, takes camera name as string
pi.GetLatestImage(DataBinder.Eval(Container.DataItem, "Name"))
    Retrieve latest image, takes camera name as string
  #51
Old August 30th, 2011, 08:55 PM
Wadenut's Avatar
OverSeer
hmm. Sometimes the most obvious solutions are the most difficult to envision.
I use the plugin & events to capture images, ie. The doorbell snaps a pic of the visitor. This might be a simpler route. Thanks Pete.
  #52
Old August 30th, 2011, 09:29 PM
Pete's Avatar
OverSeer
Yes; I just use a bit of a hodgepodge. The mix provides a nice rendition.
Huggy; I still utilize netcam; just not in "vivo"; cuz of the ASP page load.
Doorbell event is three views kind of back to the future as Zoneminder is constantly recording; such that when an event is triggered; it goes back to the frame that triggered it and saves a few seconds of stills (motion). With Netcam, et al the snapshots are "just in time" so I really don't get the walking up to the doorbell; but more the walking away from the door bell. The combo works; as I push these events to the HSTouch screens such that the event goes to the front door cam. I do similiar to the little 3.5" Chumby; but via a widget which grabs the stored netcam pics and displays them.
My wife is even looking at the touchscreens now when the doorbell rings. She never did before.
Another thing lately is that I've purchased wireless digital screens for the family for Christmas; I kind of manage all of the pics on them (family archivist); so I put some cam shots / weather shots on my family's digital frames. BTW the ultimate picture frame gift is the Chumby (Infocast 8").
  #53
Old September 7th, 2011, 10:03 AM
randman randman is offline
Seer Deluxe
Quote:
Originally Posted by Matt2.0 View Post
The link was updated, the installer should now display the proper version number.
I'm a bit confused on the version number...
I got a new HomeTroller PRO S3 (just purchased last month). I ran Updater, and the version of the NetCam that showed up is 1.1.0.0.
I installed it, and the Event Log said:
9/7/2011 9:28:41 AM - Plug-In - Found plug-in: NetCAM, version: 1.1.0.0
Given that 1.1.0.1 came out a long time ago (2009), why didn't the updater find 1.1.0.1?
Or do I really have 1.1.0.1 but it shows up as 1.1.0.0 (there was a previous post in this thread that implied this might be the case)?
If I do have 1.1.0.0., how do I download and manually install 1.1.0.1 if the updater can't find 1.1.0.1?
Thanks.
  #54
Old September 7th, 2011, 10:20 AM
Rupp's Avatar
OverSeer
Thanks.
Look in the sticky threads of this forum for the latest beta which is 1.1.0.1 There's a MSI installer and if the older version had an installer you should remove it using the add/remove programs or manage programs control panel applet.
  #55
Old September 7th, 2011, 12:03 PM
Seer Deluxe
Thanks, Rupp! So, even though the plugin came out in 2009, it's still a beta? Is that why the version available in the Updater is stil 1.1.0.0? Wondering if I should stick with official release (1.1.0.0) or go with beta (1.1.0.1).
Thanks.
  #56
Old September 7th, 2011, 12:45 PM
huggy_d1's Avatar
Seer Master
Thanks.
Go with the 'beta'!!!
  #57
Old September 7th, 2011, 01:27 PM
Pete's Avatar
OverSeer
When you install it make sure your ini file doesn't have old stuff. In fact just make a copy of it and start fresh; doing one link at a time; checking each link for each cam as you create it. I noticed one typo in the link would cause the plugin to error out. As Huggy mentioned the beta is better than the release version posted.
  #58
Old September 7th, 2011, 11:14 PM
Seer Deluxe
Okay, I'm convinced. I'd like to replace 1.1.0.0 with 1.1.0.1.
When I installed 1.1.0.0, I used the HomeSeer Updater. I don't see anything in Add/Remove Programs for Netcam. Some questions:
1. Should I remove 1.1.0.0 first? Is this the best way to do it?:
http://board.homeseer.com/showthread.php?t=117892
2. Then, delete NetCam.ini in the HomeSeer Config directory (I've only added one camera so far, but I have 7 to configure after installing 1.1.0.1).
3. Download ftp://ftp.homeseer.com/updates/Beta/NetCam1_1_0_1.msi .
Do I just run this while HomeSeer is running, and it will automatically install?
Then, restart HomeSeer.
Thanks again.
HTML code is Off
