Z-Wave error never seen before
    I am pretty new to Z-wave stuff and totally new to HS3.
    I have used it with HS2 and my thermostat, but have never seen this error before.
    I have no clue what it means.
    Apr-24 8:22:56 PM Z-Wave Error Interface01: Error, the Z-Wave API Transmit Queue is not empty after waiting 20 seconds - the interface may be disconnected or not operational (Interface01).
    Tim
    FB Page - https://www.facebook.com/pages/Capt-Tim/209398425902188
    HSTouch Layouts - https://www.facebook.com/media/set/?...5902188&type=3
    Just checked the log again and it stopped.
    Now I got this -
    Apr-24 8:27:38 PM Z-Wave Interface01: Controller Manufacturer: Aeon Labs, ID=0x1, Type=0x2
    Apr-24 8:27:38 PM Z-Wave Interface01: Controller firmware version: 3.7
    Apr-24 8:27:38 PM Z-Wave Interface01: Z-Wave Serial API version: 5
    Apr-24 8:27:38 PM Z-Wave Interface01: Z-Wave interface node ID: 1, Home ID: 01850CA8
    Apr-24 8:27:38 PM Z-Wave Interface01: Found 2 Z-Wave nodes in interface node ID 1 (Interface01)
    Apr-24 8:27:38 PM Z-Wave Interface01: Z-Wave PC Controller Library Version: Z-Wave 2.78 (ZDK 5.02.3 Patch 3)
    Apr-24 8:27:38 PM Z-Wave Interface01: Z-Wave PC Controller is Type: Static Controller
    Must have been a hickup
    Tim
      This is actually a very old and annoying message, that the HomeSeer team is unable to reproduce
      https://bugzilla.homeseer.com/bugzil...ug.cgi?id=2473
      stefxx
        I also get that message every so often. It happens after Homeseer looses connection to my USB SmartStick+. Once I get the Homeseer PC to see the USB stick again, it stops and all is good.
          I too, am seeing usb (Z-Stick 2) disconnects/unable to access all zwave devices, quite random. I have now started to monitor it vi my nagios system... so far not seen the issue since doing so.. very odd problem, and very annoying.
          So is it HS3 or the Z-Stick 2 driver, which I'm running the latest.
          As a number of people are seeing the issue, I doubt it's the hardware, still possible, but not probable.
          John
            same issue
            Getting the same error, maybe something to do with .318?
