I'm just trying out Doo Motion to see if it would fit my needs (I new to this one). It seems like a really cool plug in, but it seems to slow reaction time way down. I'm runnning HS version 2.1.102 and plugin version 2.2.53.
I have very simple setup. I use a motion senor connected to a ELK panel. I have a HS event that triggers a light on when that motion sensor tiggers. It responds in 1 second or less.
I then installed Doo Motion 2.2.53. I created a virtual motion sensor w1, that I set it's trigger code to /7 (ELK motion sensor). I then put the following code in the custom action code for that device=on.
dm.NewNoMotionDelayedEvent "Shop Light Control", "Basement Shop Lightsff", 10
This all works just fine now. The light goes on when I walk into the room then turns off 10 minutes later.
The problem is that my response time for the light to go on is now 2-5 seconds! Pretty consistant 2 seconds, but sometimes longer. This is way too long. If I click on the tray icon and set the doo motion pugin to Inactive, I then get my 1 second response time back.
So, is this normal? I would love to use this plugin becasue it seems to bring alot to the table, but I can't have response times this long.
Any ideas?
Chad.
Any ideas?
Chad.
