I have 3 HSM100s installed all with the same configuration and all see about the same amount of 'motion' in the house.
Delay off 10 Minutes
LED Off
Sensitivity 200
Wake Up 1440 Minutes
Device Activation ON
Sleep State Sleep
The Temperature and Light levels are configured as 'Do not commands from this device' and the log file confirms that only the battery levels are recorded every 24 hours.
One of the three HSM100s consumes all its battery power every 45 days or so while the other two HSM100s continue to function normally. The last batteries I used were 3 Energizer Advance Lithium items, each at a nominal 1.800 volts (using DVM 1.5v battery load tester) when put into service. When replaced today, the 3 batteries were ~1.4, 0.7, and 0.4 volts.
Are there any known issues here, maybe a 'bad' HSM100? TIA.
Mark
LED Off
Sensitivity 200
Sleep State Sleep
Mark
