Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Software > HS3Touch™ > HS3Touch Beta Releases
HS3Touch Beta Releases Discussion area for the beta releases of HomeSeer HS3Touch software
  #61
Old April 28th, 2017, 09:44 AM
happnatious1's Avatar
happnatious1 happnatious1 is offline
Seer Master
getting the designer to reliably detect clients in which to deploy projects is spotty to non-existant when running 3.0.51 of the designer, with 3.0.0.103 of HSTouch server and .156 android client.
Rolling the HSTouch server back to 3.0.0.68 seems to have fixed the issue.
  #62
Old April 28th, 2017, 09:48 AM
rjh's Avatar
rjh rjh is offline
HomeSeer Technologies
The 103 client is stuck in Beta at the moment and probably should not be used. The only real change with that one is the support for streaming video, which is currently not working reliably. I know it works fine for some, hence the reason I am leaving it there.
Rich,
  #63
Old June 6th, 2017, 06:46 PM
spknapp's Avatar
spknapp spknapp is offline
Seer Master
Quote:
Originally Posted by rjh View Post
Version 1.0.0.157 of the Android HSTouch client is available for testing.
See the end of this post for download information.
Changes in 157:
* Fixed passcode timeout setting not being honored
Is version 157 supported on the IWAR7? I installed it and it errors out with process homeseer stopped unexpectedly, then presents a Force Close button. I searched the forum but couldn't find anything related.
Steve
Steve
(System configuration is in my profile)
  #64
Old August 3rd, 2017, 11:21 AM
jpape's Avatar
jpape jpape is offline
Seer Master
Version 1.0.0.157 of the Android HSTouch client does not seem to be working for me. When i use the client with a project that has a "lock" screen, every screen that i try to open is causing the lock screen to appear even though there is no passcode assigned to the screen that i am trying to open. Using HSTouch Server 3.0.0.104
Last edited by jpape; August 4th, 2017 at 11:38 AM. Reason: Provided HSTouch Server version
  #65
Old August 3rd, 2017, 11:53 PM
mstukel mstukel is offline
Seer Plus
Quote:
I am having the exact same experience too. I have *.157 installed on my on my HomeSeer WFTT07 tabletop and the passcode screen is popping up on all of my screens (even though I have defined a passcode requirement for just 3 screens). I am using Designer *.51 and HS Touch Server Plugin *.68.
Last edited by mstukel; August 4th, 2017 at 12:36 AM. Reason: To provlde more detail
  #66
Old August 9th, 2017, 02:13 PM
BattleDroid BattleDroid is offline
Seer
I am fairly new to HS. How do I report issued with this beta? Borders do not show in the Android client for buttons and text boxes. I am running the latest official releases of server software.
Sent from my SM-G925T using Tapatalk
  #67
Old August 9th, 2017, 06:18 PM
rjh's Avatar
rjh rjh is offline
Post a screen shot of what you are seeing. I have never heard of this issue before. Note that some features in the designer do not show up on all clients due to differences on how things are rendered. Normally, buttons do not have any borders. To get a border, use a graphical background.
  #68
Old August 13th, 2017, 01:02 PM
Seer
Missing Borders
Here is a screen shot from windows client and Android. You can see that Android is now showing borders on any objects. Is that happening by design?
  #69
Old August 14th, 2017, 03:22 PM
rjh's Avatar
rjh rjh is offline
I see the problem, the border setting was not being honored on windows. Looks like it was always this way. I have put in fix. You can try the latest build:
https://homeseer.com/updates3/SetupHSTouch_3_0_0_52.exe
  #70
Old August 14th, 2017, 10:42 PM
jpape's Avatar
Seer Master
Has there been any movement regarding the above issue?
  #71
Old August 15th, 2017, 09:15 AM
jetkit jetkit is offline
Seer Deluxe
Same here. All screens are asking for passcode
  #72
Old August 28th, 2017, 06:58 PM
Seer
Frequent Crashes
I am running the beta version of the app on Samsung Galaxy 6s, but this has been happening to me with the official version as well. App crashes frequently when I use it for while or when I wake up my phone. When I try to re-start it using the on-screen pop-up, I get a connection failed message. When I try to connect, I get a message stating that my configuration can not be found. To clear it off, I need close the app completely and re-connect. Obviously, it would it great if the app did not crash in the first place. But when it does, recovery would be better is re-start option worked. Any ideas on stopping the crashes or fixing the recovery?
  #73
Old August 28th, 2017, 08:09 PM
Seer
I had this issue as well. I solved it by removing default password found on the HSTouch setup screen.
  #74
Old September 11th, 2017, 04:29 PM
rjh's Avatar
rjh rjh is offline
This is fixed in build 1.0.0.160 which has been released and is in the App Store.
  #75
Old September 12th, 2017, 03:06 PM
sidepipe sidepipe is offline
Seer
Version .160 breaks ClientAction 45 in an even more "interesting" way than it was before. It used to be that:
somestring = "Android:Client1"
hs.PluginFunction("HSTouch Server", "", "ClientAction", New Object() {45, client, "Selected Devices:Client Name:" & somestring, ""})
would set the text property of "Selected Devices:Client Name" to "Selected Devices:Client Name:Android:Client1".
It now seems to set it to just "Android". Also, not sure if the last parameter now needs to be set to non-empty string for it to do anything at all.... I'd spent so long trying to work out how you'd completely broken my house AV remote controls and had lost the will to live by then.
  #76
Old September 12th, 2017, 08:23 PM
aldo's Avatar
aldo aldo is offline
Super Seer
This version is crashing my Samsung Tab, how do I get back to the previous release, I'm looking everywhere in the forum but I can not find it.
Aldo
  #77
Old September 12th, 2017, 08:31 PM
rjh's Avatar
rjh rjh is offline
The release notes have a link to the APK. Just change the link to the version you want, they are all on our server.
Quote:
Aldo
  #78
Old September 12th, 2017, 08:47 PM
Seer Plus
I have tested on my Samsung Galaxy S7 and on my HomeSeer WFTT07 and this version of the android client is working great for me - best performance I have had so far with HSTouch - Thanks
  #79
Old September 13th, 2017, 09:51 AM
E1SEER E1SEER is offline
Seer Plus
I think
With default user name and passwords its working ok
When you set other user and passwords it crashes
V:160 Android
HS 357
  #80
Old September 14th, 2017, 08:57 AM
TeleFragger's Avatar
TeleFragger TeleFragger is offline
OverSeer
Galaxy Note 8
V:160 Android
HS 357
all good.. with default project
HS - HS3 Pro Edition 3.0.0.368
Plugins - BLLAN 2.0.38.0 | BLRF 2.0.93.0 | Concord 4 3.1.13.8 | HSTouch Server 3.0.0.68 | RFXCOM 30.0.0.36 | X10 3.0.0.36 | Z-Wave 3.0.1.150
HTML code is Off
HSTouch Android Client 1.0.0.107 Beta rjh HS3Touch Beta Releases 22 December 22nd, 2014 03:33 PM
HSTouch Android Client Beta 1.0.0.29 rjh Clients - Android 46 June 7th, 2012 10:48 AM
Android client beta 0.0.9 is posted rjh Clients - Android 50 December 24th, 2010 07:13 PM
Android client beta 0.0.6 is posted rjh Clients - Android 8 October 22nd, 2010 12:06 PM
Android client beta 0.0.4 is posted rjh Clients - Android 18 October 22nd, 2010 09:19 AM
