Go Back   HomeSeer Message Board > Audio / Video and Infra-red (IR) Plug-ins > Audio / Video and Infra-red (IR) Discussion > HomeSeer Square Connect Plug-in
HomeSeer Square Connect Plug-in Discussions related to the Square Connect IR controller and related HomeSeer supplied plug-in.
Old February 17th, 2012, 11:05 AM
pauln pauln is offline
Problems enabling SQ Blaster Plugin - Fixed!
I've installed the SQ Blaster Plugin, but when I click the 'Disabled' button nothing happens.
I'm running Homeseer Pro 2.5.0.49 on a Hometroller SE
The only message in the log that I see is:
2/16/2012 7:44:30 PM Error Unable to initialize Infrared interface SQ Blast :Either no license or trial has expired
Under 'Licenses' I see SQ Blaster as licensed 'ID 0' (in common with other included plugins for HS PRO)
Any ideas what is wrong?
Paul
Old February 17th, 2012, 11:13 AM
Rupp's Avatar
Rupp Rupp is offline
Paul
Paul,
Unfortunately you have hit an age old bug that is caused by not using Internet Explorer to enable a plugin. Try using IE to disable the plugin. Then restart HomeSeer and then try enabling the plugin using IE.
-Rupp
Old February 19th, 2012, 06:56 AM
Brilliant - that fixed it - thanks, was driving me slightly crazy...!
