Is there something I'm doing wrong, or need to do to trigger discovery?
I have 2Wemo Mini Smart Plugs.
----------------- Logging started on 2018-07-05 14:49:01.1708 ------------------ 2018-07-05 14:49:01.1152| INFO|HSPI_Wemo.HSPI.ShutdownIO |HomeSeer shutting down Wemo plugin 2018-07-05 14:49:02.6471| WARN|HSPI_Wemo.Program.client_Disconnected |Disconnected from HomeSeer server! 2018-07-05 14:49:02.6471| WARN|HSPI_Wemo.Program.Main |Connection to HomeSeer lost, shutting down plugin... ----------------- Logging finished on 2018-07-05 14:49:04.6816 -----------------
