Hi All,
Just in the process of moving my install to HS3. HS3 is all installed and appears to be 'working'.
A few little things I'm stuck on. I've done a search and kind first answers, so my apologies if these have been covered. (Is there a bug list somewhere?)
- When adding an X10 Interface, I had to set it to TI103/213 and set some options, then put it back to CM110 Compatible before it would work. Just installing the interface and setting to CM110 results in a missing X10.ini file and no commands are sent/received. This is the only way I could get it talking.
- When adding or editing a device, if I modify the settings in "Status Graphics" then add the device, the device code is wiped out.
- If I add a device and forget to set the X10 code, it cannot be added later as the X10 tab dissapears. I have to delete the device and start again. (Why is there two codes anyway?)
- Is there any way to change the size of the status graphic on the home page, it appears to be 32x32 and is rather large, adding lots of wasted space between the rows. I tried using a smaller graphic, but it just resized it larger.
- I can't seem to find a way to add a device type for devices? If I add an X10 device for example and set it's device type. Then save the device. The device type is not shown in the list. I also can't see anywhere to modify the device types available as you could in HS2.
- When using the ZWave / X10 Interface, you get a command window opened for each one. Same for the initial startup window. Is there any way to hide these? I use the server for other things and it's annoying to have all these windows open or in the task bar. HS2 used to hide in the icon bar.
Any help appreciated.
