S6 UltraCID3 on Win 10
    Just got around to installing UltraCID3 with a Zoom USB 3095.
    Plug-in status is ok but the device states not connected.
    I checked the Win 7 embedded device manager and I see the USB modem properly installed.
    The device manager states the modem is on port 7.
    I am running an Intel Win 10 Home stick.
    I set it up as modem on the Win 10 operating system of the stick using caller ID software and it works.
    Thanks for any help.
    Bob
    There is a section within the UltraCID3 HSPI User's Guide that walks you through the troubleshooting process. In summary, you'll connect to your modem via PuTTYTel, then issue the commands the plug-in does, then call your phone to see if caller Id is being reported.
    Ultrajones
      Thanks I will report results when I complete the troubleshooting process.
        I have the plugin working on com port 7 of my S6 controller. Could not get the modem to connect on com port 6. I will look at that issue later as that IU s not an issue with the plugin. Thank you
