will you offer support soon for wemos NodeMCU Arduino boards? I have automated a ton of stuff with Alexa and this development board and getting it interfaced to Homeseer would be AWESOME!!
wemos NodeMCU
Originally posted by drmcp View Postwill you offer support soon for wemos NodeMCU Arduino boards? I have automated a ton of stuff with Alexa and this development board and getting it interfaced to Homeseer would be AWESOME!!
For example, I use nodemcu's to read various sensors, then publish the data via MQTT. Homeseer picks it up into a device and I can then run events based on the value. You'll need a broker on the network and mosquito is a good choice, open source, easy to install and configure etc but its by far the only choice.
You can interface the NodeMCU with Homeseer at the moment if you use the Beta version of the Arduino plugin.
Greig.Zwave = Z-Stick, 3xHSM100� 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
Scripts = Various
Originally posted by drmcpi had the Beta installed and it found my OEM wemos devices, and did not show my NodeMCU's so i did the upgrade started this post went out cut some wood (i know to much detail) and now i see the NodeMCU in Homeseer but it will not control them, should i down grade my version and if show how uninstall and install Beta i am guessing
Originally posted by drmcp View Postwemo plug in finds my NodeMCU devices but will not turn them on and off, they receive the request but the request don't have the on or off message
Originally posted by kingfetty View PostI'll work on getting the NodeMCU working after I get the Insight plug features working. You're gonna have to bear with me as I'll be out of commission for a couple of weeks due to surgery on my hand tomorrow.
Good luck with the surgery and Godspeed on the recovery! Surgery is no fun. Hope it is breezy for you and they fix up everything with ease.
Originally posted by drmcp View PostHope all went well and you have recovered with great results!
Just to give you an update here and set expectations. I've combed through the fauxmo code and documentation (the code flashed to the nodeMCU that emulates Wemo) and it does not seem to support a few vital commands such as "GetBinaryState" or event subscriptions.
To level set here's what will be possible once I've completed my part.
- Status of the devices will always be unknown, you will not know if it's on/off and there's no way to find out.
- You will be able to control on/off of nodemcu devices with event actions or button click, but it will be a blind command.
- It will auto discover nodeMCU devices and create them in HomeSeer, I'll likely whip up a separate icon for them.
I'm brainstorming to see if there's a way I could either implement the nodeMCU commands with custom firmware I release or find some other trick to get the missing features working. I'll keep you updated here as things change, but I didn't want to leave you in the dark.
- Likes 1
Originally posted by kingfetty View PostJust to give you an update here and set expectations. I've combed through the fauxmo code and documentation (the code flashed to the nodeMCU that emulates Wemo) and it does not seem to support a few vital commands such as "GetBinaryState" or event subscriptions.
