Howdy all - I'm just starting to mess with HS3 this evening on my Hometroller SE-PRO, and most things are working great. However, I'm running into some issues with the Nest plugin.
I've got it installed (3.0.0.11), and I did the auth process. After entering my Nest pin, the plugin just spins. This error occurs in the logs:
Any suggestions? If I can get this fixed, I'll have my HS3 setup at parity with my HS2 setup in just an hour or so.
Feb-11 9:51:00 PM Warning Plugin Nest is not responding but it is still running, not restarting yet. Feb-11 9:50:56 PM Error Posting back to plugin web page nestconfig: Object reference not set to an instance of an object.-> at System.Runtime.Remoting.Messaging.LogicalCallContext.PropagateIncomingHeadersToCallContext(IMessage msg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.PostBackProc(String page, String data, String user, Int32 userRights) at Scheduler.proxyPage.postBackProc(StateObject& state, String Data) Feb-11 9:50:34 PM Error Posting back to plugin web page nestconfig: Object reference not set to an instance of an object.-> at System.Runtime.Remoting.Messaging.LogicalCallContext.PropagateIncomingHeadersToCallContext(IMessage msg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.PostBackProc(String page, String data, String user, Int32 userRights) at Scheduler.proxyPage.postBackProc(StateObject& state, String Data)
