Hi everyone. I am adding some Homeseer devices to my house. I'm very pleased with them so far but I'm having trouble with a 3-way.
I have already wired one 3-way that is configured with a 3-wire running between the two switch boxes. Works great! I have a second 3-way where the lights are between switch boxes so its configured a little differently. This is the result of a remodel. Previously, I had two non-automated three way switches installed and they worked fine. I had line (bl), load (bl) and traveler (red) wired to one switch (WD100 side). On the other switch (WA100 side) I had black going to the common terminal and red and white to the traveler terminals. Since the WA100 only has one traveler terminal I cannot copy this configuration so I'm not quite sure what to do. On theWA100 side if I tie off the white and the black the WD100 works but the WA100 companion switch does not. Does this make sense? Sorry if its confusing. Any thoughts? Thanks in advance for your help.
Dave
Dave
