I am thinking of getting a Zee and I am curious if this plugin will work with the Zee.
Anyone set this up with a Hometroller Zee?
The Zee supports a very limited number of plugins: Z-Wave, Insteon, X10 and HSTouch
http://www.homeseer.com/homeseer-plug-ins.html
Moreover the Nest plugin is not compatible yet with Linux (I have never tested it under linux, and it probably needs a few changes)
But I will work on that soon.
as I said in the other thread I can't port it to the Zee because the HS3 version running on the Zee is a variant of the regular HS3 Linux in which third party plugins are not supported (or at least it's not documented how to port a plugin for this version)
I gotcha, sorry I misunderstood. When you said you had not tested it on Linux I thought that meant all you had to do was port it to Linux (I understand this is not trivial ) and then it would run on the Zee. I suppose I have to really evaluate if the Zee is going to be able to do what I want it too before I get one.
Thanks Spud!
Originally posted by DeVon View PostLooking at this plugin for Nest Thermostat. Wondering if it will work with my Zee2? I see it didn't in the past, but the instructions say it works with Linux. Does that mean it works now?
The Zee1 was special because the plugins needed to have a specific format (dll instead of exe). Only a few of the HS plugins were supported.
Originally posted by DeVon View PostWill I be able to use motion sensors connected to ZeeS2 to put Nest into or out of away mode? My thermostat is in a hallway that sometimes never sees traffic.
