I am attempting to change the Target Temperature from the Device Management Page and I receive the following entries in the log.
I am running Homeseer HS3 Standard Edition 3.0.0.130 and Nest Plugin 3.0.0.8. I have also noted the my Fan Device does not change from an on and off state. Any ideas what may be causing this? Thanks.
P.S. I have restarted both the plugin and HS3 multiple times during troubleshooting.
Nov-12 09:44:12 Nest DEBUG System.AggregateException: One or more errors occurred. ---> System.Net.Http.HttpRequestException: An error occurred while sending the request. ---> System.Net.WebException: The underlying connection was closed: An unexpected error occurred on a send. ---> System.InvalidOperationException: This operation cannot be performed on a completed asynchronous result object. at System.Net.ConnectStream.WriteHeadersCallback(IAsyncResult ar) --- End of inner exception stack trace --- at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Net.Http.HttpClientHandler.GetResponseCallback(IAsyncResult ar) --- End of inner exception stack trace --- at Microsoft.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at Microsoft.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccess(Task task) at FirebaseSharp.Firebase.d__3.MoveNext() --- End of inner exception stack trace --- at System.Threading.Tasks.Task.ThrowIfExceptional(Boolean includeTaskCanceledExceptions) at System.Threading.Tasks.Task`1.GetResultCore(Boolean waitCompletionNotification) at System.Threading.Tasks.Task`1.get_Result() at NestSharp.NestClient.SetTargetTemperature(String thermostatId, Double target, String scale) at HSPI_Nest.NestApp.ButtonPress(String buttonName, Double value, Int32 dvref) ---> (Inner Exception #0) System.Net.Http.HttpRequestException: An error occurred while sending the request. ---> System.Net.WebException: The underlying connection was closed: An unexpected error occurred on a send. ---> System.InvalidOperationException: This operation cannot be performed on a completed asynchronous result object. at System.Net.ConnectStream.WriteHeadersCallback(IAsyncResult ar) --- End of inner exception stack trace --- at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Net.Http.HttpClientHandler.GetResponseCallback(IAsyncResult ar) --- End of inner exception stack trace --- at Microsoft.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at Microsoft.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccess(Task task) at FirebaseSharp.Firebase.d__3.MoveNext()<--- Nov-12 09:44:12 Nest ERROR One or more errors occurred. Nov-12 09:44:11 Nest DEBUG PUT: path=devices/thermostats/SyE7pSBxL5MTw0bAMtuwPg_VumSUMP-v payload={"target_temperature_c":19.5} Nov-12 09:44:11 Device Control Device: Nest Target Temperature High to + (1001) by/from: CAPI Control Handler
