Installed my Nest thermostat yesterday, along with the plug-in. Set up and tested my events to set the mode and target temps. All worked fine. Evening event fired correctly. The morning heat-on (set high temp) did not work.
When I checked the log, there were no error messages, but I could not change anything from the device management page. Stopped and restarted plug-in and all is well again.
I want to do all the scheduling myself, but have left the thermostat in learning mode for now. Should I disable it or any of the other device settings?
Also, should I turn on debug logging or is there a "heart-beat" event that I could use to see if I need to do a restart?
Barry
Barry
