I'm glad, you finally got it to work!
Plugin stopped reading Nest data
Originally posted by spud View PostI have no idea what could be causing this. Could you post the full debug logs after a plugin restart.
How many thermostat and smoke detector do you have?
Is anyone else seeing this error?
Originally posted by melkin View PostI am experiencing the exact thing as this user. I am using .Net 4.0 on HomeTroller S5 and the plugin stopped working on June 11
Can you confirm that it is the exact same error, i.e you see "Authentication failed because the remote party has closed the transport stream" in the logs
I will have to test and debug with Net 4 to try to replicate it, unfortunately I'm on vacation right now, so I won't be able to do it before july 1st
HomeTroller S5
Hi again,
Sorry, just saw your last post. Yes, the HomeTroller S5 will not allow .Net 4.5.
I will check the error logs. My experience of the error is exactly as the other user describes. For example, the thermostat does receive commands but there is no updating of the status. All was working until June 11.
Thanking you,
Mark.
Jul-01 7:12:13 PM Nest DEBUG System.AggregateException: One or more errors occurred. ---> System.Net.Http.HttpRequestException: An error occurred while sending the request. ---> System.Net.WebException: The underlying connection was closed: An unexpected error occurred on a send. ---> System.IO.IOException: Authentication failed because the remote party has closed the transport stream. at System.Net.TlsStream.EndWrite(IAsyncResult asyncResult) at System.Net.PooledStream.EndWrite(IAsyncResult asyncResult) at System.Net.ConnectStream.WriteHeadersCallback(IAsyncResult ar) --- End of inner exception stack trace --- at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Net.Http.HttpClientHandler.GetResponseCallback(IAsync Result ar) --- End of inner exception stack trace --- at Microsoft.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSu ccess(Task task) at Microsoft.Runtime.CompilerServices.TaskAwaiter.HandleNonSucc ess(Task task) at FirebaseSharp.Firebase.d__f.MoveNext() --- End of inner exception stack trace --- at System.Threading.Tasks.Task.ThrowIfExceptional(Boolean includeTaskCanceledExceptions) at System.Threading.Tasks.Task.Wait(Int32 millisecondsTimeout, CancellationToken cancellationToken) at System.Threading.Tasks.Task`1.get_Result() at NestSharp.NestClient.StartMonitoringData() ---> (Inner Exception #0) System.Net.Http.HttpRequestException: An error occurred while sending the request. ---> System.Net.WebException: The underlying connection was closed: An unexpected error occurred on a send. ---> System.IO.IOException: Authentication failed because the remote party has closed the transport stream. at System.Net.TlsStream.EndWrite(IAsyncResult asyncResult) at System.Net.PooledStream.EndWrite(IAsyncResult asyncResult) at System.Net.ConnectStream.WriteHeadersCallback(IAsyncResult ar) --- End of inner exception stack trace --- at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Net.Http.HttpClientHandler.GetResponseCallback(IAsync Result ar) --- End of inner exception stack trace --- at Microsoft.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSu ccess(Task task) at Microsoft.Runtime.CompilerServices.TaskAwaiter.HandleNonSucc ess(Task task) at FirebaseSharp.Firebase.d__f.MoveNext()<---
Jul-01 7:12:13 PM Nest DEBUG Method: GET, RequestUri: 'https://developer-api.nest.com/.json?auth=c.4Th7UmY2tfY55vOznt6Hd8MUUiOvDCgdOzIxC1XnS9seGnK tMDMpaWWrUbCzNYoywDDaWrgt13P18h4DrQnY6hcsdxFKCcgTVMEAIq0vlPC 7g8vE74b9u7druSOldxwx0Bg2CazWfuzavaPa', Version: 1.1, Content: , Headers: { Accept: text/event-stream }
Originally posted by melkin View PostHi Spud,
Thanks for looking into this for me. I am using the HomeTroller that can only run WinXP with .Net 4.0 and yes, I am still getting the error.
Is there any suggestions you might have to help me help you to debug this?
Thanks again,
Mark.
So unless they change back the configuration of their servers to accept at least one of these ciphers, we are screwed.
I posted on stack overflow about this issue as this is where they advise developers to report questions about the Nest API: http://stackoverflow.com/questions/3...xp-server-2003
However I would advise to upgrade to a newer HS controller because win XP is no longer supported, so I guess problems like this one will happen
more and more frequently.
Hi Spud,
I just wanted to thank you for your help. I took your advice and moved everything to a HomeTrollerS6 and everything is working now.
I just wanted you to know that your plugins are invaluable and as far as I am concerned a critical addition to HomeSeer.
Thanks again for all of your efforts.
Mark.
Mark.
My plugin is not working. I'm getting this in the logs. I can confirm that I can control the thermostat through the next website but when I go to change the device by hitting the + or - buttons I get this:
Aug-01 3:42:46 PM Nest ERROR One or more errors occurred.
Aug-01 3:42:45 PM Device Control Device: Nest HVAC Mode to Heat (1) by/from: CAPI Control Handler
Aug-01 3:42:42 PM Nest ERROR One or more errors occurred.
Aug-01 3:42:42 PM Device Control Device: Nest Target Temperature Low to + (1001) by/from: CAPI Control Handler
Aug-01 3:42:40 PM Nest ERROR One or more errors occurred.
Aug-01 3:42:40 PM Device Control Device: Nest Target Temperature High to + (1001) by/from: CAPI Control Handler
Aug-01 3:42:17 PM Nest ERROR One or more errors occurred.
Aug-01 3:42:16 PM Device Control Device: Nest HVAC Mode to Off (0) by/from: CAPI Control Handler
I should say I am running Windows 7 and using 3.0.0.13 of the plugin. I tried doing the reauthorization process and deleted all devices and started over with the same error occurring.
Originally posted by jayman13 View PostMy plugin is not working. I'm getting this in the logs. I can confirm that I can control the thermostat through the next website but when I go to change the device by hitting the + or - buttons I get this:
