I'm assuming the answer is simply "NO" since this is obviously not stated. Also because (from my research) it appears that Nest is doing everything possible to keep you from using your cam data locally (so that you pay for the Nest Aware service). But I'll ask anyway:
Is (or will) the Nest Cam supported on Homeseer with this (or any other?) plugin?
