Originally posted by mattdb
View Post
Nest plugin wont authorize
mattdb's problem was indeed caused by the updated lines in C:\Windows\Microsoft.NET\Framework\v4.0.30319\Config\machine .config
I have confirmed with the developers of MainLobby that these lines are inserted when you install MLServer and they said they are only needed if you use the Calendar app.
I asked them to try to find a better solution that do not impact other softwares but they have not responded yet.
Originally posted by brett_cp View PostWas this issue ever resolved? I use MainLobby (with the calendar app) and HS3 on Windows 10 Pro, and would like to purchase this Nest plugin, but I get the same issue as mentioned in the first post of this thread. Thanks!
You can try to manually remove the lines they added in C:\Windows\Microsoft.NET\Framework\v4.0.30319\Config\machine .config
change
<runtime><!-- UPDATE:03 -->
<assemblyBinding xmlns = "urn:schemas-microsoft-com:asm.v1" >
<dependentAssembly>
<assemblyIdentity name="System.Runtime" publicKeyToken="b03f5f7f11d50a3a" culture="neutral"/>
<bindingRedirect oldVersion="0.0.0.0-2.6.10.0" newVersion="2.6.10.0"/>
</dependentAssembly>
<dependentAssembly>
<assemblyIdentity name="System.Threading.Tasks" publicKeyToken="b03f5f7f11d50a3a" culture="neutral" />
<bindingRedirect oldVersion="0.0.0.0-2.6.10.0" newVersion="2.6.10.0" />
</runtime>
To just
</runtime>
then reboot
they are chances that it does not even break MainLobby
Originally posted by upstatemike View PostJust tried to install the Nest plugin and got this error... is this the same as what is being discussed here?
do you have this error immediately after you start the plugin and go to the config page? If so please restart it, then post your logs.
Originally posted by upstatemike View PostYes I go in and it says the plugin is already authorized but there are no devices created so I authorize again and things just lock up.
Could you try to restart from scratch:
- stop the plugin and make sure to kill any hanging HSPI_Nest.exe process
- delete the Config/Nest.ini file
- start the plugin
- go to the config page and set the log level to Debug
- do the authorization process again
- start the plugin
- start the plugin
i am having the same issue as the last poster. He didnt mention what he did to fix it? any thoughts? thanks. windows 7
DEBUG Retrying in 5 seconds...
Nov-19 11:57:30 PM Nest DEBUG System.IO.FileLoadException: Could not load file or assembly 'System.Threading.Tasks, Version=2.6.10.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040) File name: 'System.Threading.Tasks, Version=2.6.10.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' ---> System.IO.FileLoadException: Could not load file or assembly 'System.Threading.Tasks, Version=2.6.8.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040) File name: 'System.Threading.Tasks, Version=2.6.8.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' WRN: Assembly binding logging is turned OFF. To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1. Note: There is some performance penalty associated with assembly bind failure logging. To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog]. at FirebaseSharp.Firebase.GetStreamingAsync(String path, DataUpdatedEventHandler updated) at NestSharp.NestClient.StartMonitoringData()
Nov-19 11:57:25 PM Nest DEBUG Retrying in 5 seconds...
Nov-19 11:57:25 PM Nest DEBUG System.IO.FileLoadException: Could not load file or assembly 'System.Threading.Tasks, Version=2.6.10.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040) File name: 'System.Threading.Tasks, Version=2.6.10.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' ---> System.IO.FileLoadException: Could not load file or assembly 'System.Threading.Tasks, Version=2.6.8.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040) File name: 'System.Threading.Tasks, Version=2.6.8.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' WRN: Assembly binding logging is turned OFF. To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1. Note: There is some performance penalty associated with assembly bind failure logging. To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog]. at FirebaseSharp.Firebase.GetStreamingAsync(String path, DataUpdatedEventHandler updated) at NestSharp.NestClient.StartMonitoringData()
Originally posted by simonmason View Posti am having the same issue as the last poster. He didnt mention what he did to fix it? any thoughts? thanks. windows 7
Please post the content of this file: C:\Windows\Microsoft.NET\Framework\v4.0.30319\Config\machine .config
I do have MainLobby on the same server. Also, while I was diagnosing I removed the following from my machine.config based on another post in the forum.
Code:<dependentAssembly> <assemblyIdentity name="Newtonsoft.Json" publicKeyToken="30ad4fe6b2a6aeed" culture="neutral" /> <bindingRedirect oldVersion="0.0.0.0-7.0.0.0" newVersion="7.0.0.0" /> </dependentAssembly>
Code:<?xml version="1.0" encoding="UTF-8" ?> <!-- Please refer to machine.config.comments for a description and the default values of each configuration section. For a full documentation of the schema please refer to http://go.microsoft.com/fwlink/?LinkId=42127 To improve performance, machine.config should contain only those settings that differ from their defaults. --> <configuration> <configSections> <section name="appSettings" type="System.Configuration.AppSettingsSection, System.Configuration, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" restartOnExternalChanges="false" requirePermission="false" /> <section name="connectionStrings" type="System.Configuration.ConnectionStringsSection, System.Configuration, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" requirePermission="false" /> <section name="mscorlib" type="System.Configuration.IgnoreSection, System.Configuration, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" allowLocation="false" /> <section name="runtime" type="System.Configuration.IgnoreSection, System.Configuration, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" allowLocation="false" /> <section name="assemblyBinding" type="System.Configuration.IgnoreSection, System.Configuration, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" allowLocation="false" /> <section name="satelliteassemblies" type="System.Configuration.IgnoreSection, System.Configuration, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" allowLocation="false" /> <section name="startup" type="System.Configuration.IgnoreSection, System.Configuration, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" allowLocation="false" /> <section name="system.codedom" type="System.CodeDom.Compiler.CodeDomConfigurationHandler, System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" /> <section name="system.data" type="System.Data.Common.DbProviderFactoriesConfigurationHandler, System.Data, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" /> <section name="system.data.dataset" type="System.Configuration.NameValueFileSectionHandler, System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" restartOnExternalChanges="false" /> <section name="system.data.odbc" type="System.Data.Common.DbProviderConfigurationHandler, System.Data, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" /> <section name="system.data.oledb" type="System.Data.Common.DbProviderConfigurationHandler, System.Data, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" /> <section name="system.data.oracleclient" type="System.Data.Common.DbProviderConfigurationHandler, System.Data, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" /> <section name="system.data.sqlclient" type="System.Data.Common.DbProviderConfigurationHandler, System.Data, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" /> <section name="system.diagnostics" type="System.Diagnostics.SystemDiagnosticsSection, System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" /> <section name="system.runtime.remoting" type="System.Configuration.IgnoreSection, System.Configuration, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" allowLocation="false" /> <section name="system.windows.forms" type="System.Windows.Forms.WindowsFormsSection, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" /> <section name="windows" type="System.Configuration.IgnoreSection, System.Configuration, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" allowLocation="false" /> <section name="uri" type="System.Configuration.UriSection, System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" /> <sectionGroup name="system.runtime.caching" type="System.Runtime.Caching.Configuration.CachingSectionGroup, System.Runtime.Caching, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a"> <section name="memoryCache" type="System.Runtime.Caching.Configuration.MemoryCacheSection, System.Runtime.Caching, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" allowDefinition="MachineToApplication" /> </sectionGroup> <sectionGroup name="system.xml.serialization" type="System.Xml.Serialization.Configuration.SerializationSectionGroup, System.Xml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"> <section name="schemaImporterExtensions" type="System.Xml.Serialization.Configuration.SchemaImporterExtensionsSection, System.Xml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" /> <section name="dateTimeSerialization" type="System.Xml.Serialization.Configuration.DateTimeSerializationSection, System.Xml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" /> <section name="xmlSerializer" type="System.Xml.Serialization.Configuration.XmlSerializerSection, System.Xml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" requirePermission="false" /> </sectionGroup> <sectionGroup name="system.net" type="System.Net.Configuration.NetSectionGroup, System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"> <section name="authenticationModules" type="System.Net.Configuration.AuthenticationModulesSection, System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" /> <section name="connectionManagement" type="System.Net.Configuration.ConnectionManagementSection, System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" /> <section name="defaultProxy" type="System.Net.Configuration.DefaultProxySection, System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" /> <sectionGroup name="mailSettings" type="System.Net.Configuration.MailSettingsSectionGroup, System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"> <section name="smtp" type="System.Net.Configuration.SmtpSection, System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" /> </sectionGroup> <section name="requestCaching" type="System.Net.Configuration.RequestCachingSection, System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" /> <section name="settings" type="System.Net.Configuration.SettingsSection, System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" /> <section name="webRequestModules" type="System.Net.Configuration.WebRequestModulesSection, System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" /> </sectionGroup> <sectionGroup name="system.runtime.serialization" type="System.Runtime.Serialization.Configuration.SerializationSectionGroup, System.Runtime.Serialization, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"> <section name="dataContractSerializer" type="System.Runtime.Serialization.Configuration.DataContractSerializerSection, System.Runtime.Serialization, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/> </sectionGroup> <sectionGroup name="system.serviceModel" type="System.ServiceModel.Configuration.ServiceModelSectionGroup, System.ServiceModel, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"> <section name="behaviors" type="System.ServiceModel.Configuration.BehaviorsSection, System.ServiceModel, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/> <section name="bindings" type="System.ServiceModel.Configuration.BindingsSection, System.ServiceModel, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/> <section name="client" type="System.ServiceModel.Configuration.ClientSection, System.ServiceModel, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/> <section name="comContracts" type="System.ServiceModel.Configuration.ComContractsSection, System.ServiceModel, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/> <section name="commonBehaviors" type="System.ServiceModel.Configuration.CommonBehaviorsSection, System.ServiceModel, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" allowDefinition="MachineOnly" allowExeDefinition="MachineOnly"/> <section name="diagnostics" type="System.ServiceModel.Configuration.DiagnosticSection, System.ServiceModel, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/> <section name="extensions" type="System.ServiceModel.Configuration.ExtensionsSection, System.ServiceModel, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/> <section name="machineSettings" type="System.ServiceModel.Configuration.MachineSettingsSection, SMDiagnostics, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" allowDefinition="MachineOnly" allowExeDefinition="MachineOnly"/> <section name="protocolMapping" type="System.ServiceModel.Configuration.ProtocolMappingSection, System.ServiceModel, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/> <section name="serviceHostingEnvironment" type="System.ServiceModel.Configuration.ServiceHostingEnvironmentSection, System.ServiceModel, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" allowDefinition="MachineToApplication"/> <section name="services" type="System.ServiceModel.Configuration.ServicesSection, System.ServiceModel, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/> <section name="standardEndpoints" type="System.ServiceModel.Configuration.StandardEndpointsSection, System.ServiceModel, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/> <section name="routing" type="System.ServiceModel.Routing.Configuration.RoutingSection, System.ServiceModel.Routing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" /> <section name="tracking" type="System.ServiceModel.Activities.Tracking.Configuration.TrackingSection, System.ServiceModel.Activities, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" /> </sectionGroup> <sectionGroup name="system.serviceModel.activation" type="System.ServiceModel.Activation.Configuration.ServiceModelActivationSectionGroup, System.ServiceModel, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"> <section name="diagnostics" type="System.ServiceModel.Activation.Configuration.DiagnosticSection, System.ServiceModel, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/> <section name="net.pipe" type="System.ServiceModel.Activation.Configuration.NetPipeSection, System.ServiceModel, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/> <section name="net.tcp" type="System.ServiceModel.Activation.Configuration.NetTcpSection, System.ServiceModel, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/> </sectionGroup> <sectionGroup name="system.transactions" type="System.Transactions.Configuration.TransactionsSectionGroup, System.Transactions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089, Custom=null"> <section name="defaultSettings" type="System.Transactions.Configuration.DefaultSettingsSection, System.Transactions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089, Custom=null" /> <section name="machineSettings" type="System.Transactions.Configuration.MachineSettingsSection, System.Transactions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089, Custom=null" allowDefinition="MachineOnly" allowExeDefinition="MachineOnly"/> </sectionGroup> <sectionGroup name="system.web" type="System.Web.Configuration.SystemWebSectionGroup, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a"> <section name="anonymousIdentification" type="System.Web.Configuration.AnonymousIdentificationSection, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" allowDefinition="MachineToApplication" /> <section name="authentication" type="System.Web.Configuration.AuthenticationSection, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" allowDefinition="MachineToApplication" /> <section name="authorization" type="System.Web.Configuration.AuthorizationSection, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" /> <section name="browserCaps" type="System.Web.Configuration.HttpCapabilitiesSectionHandler, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" /> <section name="clientTarget" type="System.Web.Configuration.ClientTargetSection, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" /> <section name="compilation" type="System.Web.Configuration.CompilationSection, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" requirePermission="false" /> <section name="customErrors" type="System.Web.Configuration.CustomErrorsSection, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" /> <section name="deployment" type="System.Web.Configuration.DeploymentSection, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" allowDefinition="MachineOnly" /> <section name="deviceFilters" type="System.Web.Mobile.DeviceFiltersSection, System.Web.Mobile, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" /> <section name="fullTrustAssemblies" type="System.Web.Configuration.FullTrustAssembliesSection, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" allowDefinition="MachineToApplication" /> <section name="globalization" type="System.Web.Configuration.GlobalizationSection, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" /> <section name="healthMonitoring" type="System.Web.Configuration.HealthMonitoringSection, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" allowDefinition="MachineToApplication" /> <section name="hostingEnvironment" type="System.Web.Configuration.HostingEnvironmentSection, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" allowDefinition="MachineToApplication" /> <section name="httpCookies" type="System.Web.Configuration.HttpCookiesSection, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" /> <section name="httpHandlers" type="System.Web.Configuration.HttpHandlersSection, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" /> <section name="httpModules" type="System.Web.Configuration.HttpModulesSection, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" /> <section name="httpRuntime" type="System.Web.Configuration.HttpRuntimeSection, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" /> <section name="identity" type="System.Web.Configuration.IdentitySection, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" /> <section name="machineKey" type="System.Web.Configuration.MachineKeySection, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" allowDefinition="MachineToApplication" /> <section name="membership" type="System.Web.Configuration.MembershipSection, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" allowDefinition="MachineToApplication" /> <section name="mobileControls" type="System.Web.UI.MobileControls.MobileControlsSection, System.Web.Mobile, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" /> <section name="pages" type="System.Web.Configuration.PagesSection, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" requirePermission="false" /> <section name="partialTrustVisibleAssemblies" type="System.Web.Configuration.PartialTrustVisibleAssembliesSection, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" allowDefinition="MachineToApplication" /> <section name="processModel" type="System.Web.Configuration.ProcessModelSection, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" allowDefinition="MachineOnly" allowLocation="false" /> <section name="profile" type="System.Web.Configuration.ProfileSection, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" allowDefinition="MachineToApplication" /> <section name="protocols" type="System.Web.Configuration.ProtocolsSection, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" allowDefinition="MachineToWebRoot" /> <section name="roleManager" type="System.Web.Configuration.RoleManagerSection, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" allowDefinition="MachineToApplication" /> <section name="securityPolicy" type="System.Web.Configuration.SecurityPolicySection, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" allowDefinition="MachineToApplication" /> <section name="sessionPageState" type="System.Web.Configuration.SessionPageStateSection, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" /> <section name="sessionState" type="System.Web.Configuration.SessionStateSection, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" allowDefinition="MachineToApplication" /> <section name="siteMap" type="System.Web.Configuration.SiteMapSection, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" allowDefinition="MachineToApplication" /> <section name="trace" type="System.Web.Configuration.TraceSection, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" /> <section name="trust" type="System.Web.Configuration.TrustSection, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" allowDefinition="MachineToApplication" /> <section name="urlMappings" type="System.Web.Configuration.UrlMappingsSection, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" allowDefinition="MachineToApplication" /> <section name="webControls" type="System.Web.Configuration.WebControlsSection, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" /> <section name="webParts" type="System.Web.Configuration.WebPartsSection, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" /> <section name="webServices" type="System.Web.Services.Configuration.WebServicesSection, System.Web.Services, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" /> <section name="xhtmlConformance" type="System.Web.Configuration.XhtmlConformanceSection, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" /> <sectionGroup name="caching" type="System.Web.Configuration.SystemWebCachingSectionGroup, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a"> <section name="cache" type="System.Web.Configuration.CacheSection, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" allowDefinition="MachineToApplication" /> <section name="outputCache" type="System.Web.Configuration.OutputCacheSection, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" allowDefinition="MachineToApplication" /> <section name="outputCacheSettings" type="System.Web.Configuration.OutputCacheSettingsSection, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" allowDefinition="MachineToApplication" /> <section name="sqlCacheDependency" type="System.Web.Configuration.SqlCacheDependencySection, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" allowDefinition="MachineToApplication" /> </sectionGroup> </sectionGroup> <sectionGroup name="system.web.extensions" type="System.Web.Configuration.SystemWebExtensionsSectionGroup, System.Web.Extensions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"> <sectionGroup name="scripting" type="System.Web.Configuration.ScriptingSectionGroup, System.Web.Extensions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"> <section name="scriptResourceHandler" type="System.Web.Configuration.ScriptingScriptResourceHandlerSection, System.Web.Extensions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" requirePermission="false" allowDefinition="MachineToApplication"/> <sectionGroup name="webServices" type="System.Web.Configuration.ScriptingWebServicesSectionGroup, System.Web.Extensions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"> <section name="jsonSerialization" type="System.Web.Configuration.ScriptingJsonSerializationSection, System.Web.Extensions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" requirePermission="false" allowDefinition="Everywhere" /> <section name="profileService" type="System.Web.Configuration.ScriptingProfileServiceSection, System.Web.Extensions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" requirePermission="false" allowDefinition="MachineToApplication" /> <section name="authenticationService" type="System.Web.Configuration.ScriptingAuthenticationServiceSection, System.Web.Extensions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" requirePermission="false" allowDefinition="MachineToApplication" /> <section name="roleService" type="System.Web.Configuration.ScriptingRoleServiceSection, System.Web.Extensions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" requirePermission="false" allowDefinition="MachineToApplication" /> </sectionGroup> </sectionGroup> </sectionGroup> <sectionGroup name="system.xaml.hosting" type="System.Xaml.Hosting.Configuration.XamlHostingSectionGroup, System.Xaml.Hosting, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"> <section name="httpHandlers" type="System.Xaml.Hosting.Configuration.XamlHostingSection, System.Xaml.Hosting, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"/> </sectionGroup> <section name="system.webServer" type="System.Configuration.IgnoreSection, System.Configuration, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" /> </configSections> <configProtectedData defaultProvider="RsaProtectedConfigurationProvider"> <providers> <add name="RsaProtectedConfigurationProvider" type="System.Configuration.RsaProtectedConfigurationProvider,System.Configuration, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" description="Uses RsaCryptoServiceProvider to encrypt and decrypt" keyContainerName="NetFrameworkConfigurationKey" cspProviderName="" useMachineContainer="true" useOAEP="false" /> <add name="DataProtectionConfigurationProvider" type="System.Configuration.DpapiProtectedConfigurationProvider,System.Configuration, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" description="Uses CryptProtectData and CryptUnProtectData Windows APIs to encrypt and decrypt" useMachineProtection="true" keyEntropy="" /> </providers> </configProtectedData> <runtime><!-- UPDATE:03 --> <assemblyBinding xmlns = "urn:schemas-microsoft-com:asm.v1" > <dependentAssembly> <assemblyIdentity name="System.Runtime" publicKeyToken="b03f5f7f11d50a3a" culture="neutral"/> <bindingRedirect oldVersion="0.0.0.0-2.6.10.0" newVersion="2.6.10.0"/> </dependentAssembly> <dependentAssembly> <assemblyIdentity name="System.Threading.Tasks" publicKeyToken="b03f5f7f11d50a3a" culture="neutral" /> <bindingRedirect oldVersion="0.0.0.0-2.6.10.0" newVersion="2.6.10.0" /> </dependentAssembly> <dependentAssembly> <assemblyIdentity name="System.Net.Http" publicKeyToken="b03f5f7f11d50a3a" culture="neutral" /> <bindingRedirect oldVersion="0.0.0.0-2.2.29.0" newVersion="2.2.29.0" /> </dependentAssembly> <dependentAssembly> <assemblyIdentity name="System.Net.Http.Primitives" publicKeyToken="b03f5f7f11d50a3a" culture="neutral" /> <bindingRedirect oldVersion="0.0.0.0-2.2.29.0" newVersion="2.2.29.0" /> </dependentAssembly> <dependentAssembly> <assemblyIdentity name="Google.Apis" publicKeyToken="4b01fa6e34db77ab" culture="neutral" /> <bindingRedirect oldVersion="0.0.0.0-1.9.3.19379" newVersion="1.9.3.19379" /> </dependentAssembly> <dependentAssembly> <assemblyIdentity name="Google.Apis.Core" publicKeyToken="4b01fa6e34db77ab" culture="neutral" /> <bindingRedirect oldVersion="0.0.0.0-1.9.3.19379" newVersion="1.9.3.19379" /> </dependentAssembly> <dependentAssembly> <assemblyIdentity name="log4net" publicKeyToken="669E0Ddf0bb1aa2a" culture="neutral" /> <bindingRedirect oldVersion="0.0.0.0-1.2.14.0" newVersion="1.2.14.0" /> </dependentAssembly> </assemblyBinding> </runtime> <connectionStrings> <add name="LocalSqlServer" connectionString="data source=.\SQLEXPRESS;Integrated Security=SSPI;AttachDBFilename=|DataDirectory|aspnetdb.mdf;User Instance=true" providerName="System.Data.SqlClient"/> </connectionStrings> <system.data> <DbProviderFactories /> </system.data> <system.serviceModel> <extensions> <behaviorExtensions> <add name="persistenceProvider" type="System.ServiceModel.Configuration.PersistenceProviderElement, System.WorkflowServices, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"/> <add name="workflowRuntime" type="System.ServiceModel.Configuration.WorkflowRuntimeElement, System.WorkflowServices, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"/> <add name="enableWebScript" type="System.ServiceModel.Configuration.WebScriptEnablingElement, System.ServiceModel.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"/> <add name="webHttp" type="System.ServiceModel.Configuration.WebHttpElement, System.ServiceModel.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"/> <add name="serviceDiscovery" type="System.ServiceModel.Discovery.Configuration.ServiceDiscoveryElement, System.ServiceModel.Discovery, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" /> <add name="endpointDiscovery" type="System.ServiceModel.Discovery.Configuration.EndpointDiscoveryElement, System.ServiceModel.Discovery, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" /> <add name="etwTracking" type="System.ServiceModel.Activities.Configuration.EtwTrackingBehaviorElement, System.ServiceModel.Activities, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" /> <add name="routing" type="System.ServiceModel.Routing.Configuration.RoutingExtensionElement, System.ServiceModel.Routing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" /> <add name="soapProcessing" type="System.ServiceModel.Routing.Configuration.SoapProcessingExtensionElement, System.ServiceModel.Routing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" /> <add name="workflowIdle" type="System.ServiceModel.Activities.Configuration.WorkflowIdleElement, System.ServiceModel.Activities, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" /> <add name="workflowUnhandledException" type="System.ServiceModel.Activities.Configuration.WorkflowUnhandledExceptionElement, System.ServiceModel.Activities, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" /> <add name="bufferedReceive" type="System.ServiceModel.Activities.Configuration.BufferedReceiveElement, System.ServiceModel.Activities, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" /> <add name="sendMessageChannelCache" type="System.ServiceModel.Activities.Configuration.SendMessageChannelCacheElement, System.ServiceModel.Activities, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" /> <add name="sqlWorkflowInstanceStore" type="System.ServiceModel.Activities.Configuration.SqlWorkflowInstanceStoreElement, System.ServiceModel.Activities, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" /> <add name="workflowInstanceManagement" type="System.ServiceModel.Activities.Configuration.WorkflowInstanceManagementElement, System.ServiceModel.Activities, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" /> </behaviorExtensions> <bindingElementExtensions> <add name="webMessageEncoding" type="System.ServiceModel.Configuration.WebMessageEncodingElement, System.ServiceModel.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"/> <add name="context" type="System.ServiceModel.Configuration.ContextBindingElementExtensionElement, System.ServiceModel, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/> <add name="byteStreamMessageEncoding" type="System.ServiceModel.Configuration.ByteStreamMessageEncodingElement, System.ServiceModel.Channels, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"/> <add name="discoveryClient" type="System.ServiceModel.Discovery.Configuration.DiscoveryClientElement, System.ServiceModel.Discovery, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"/> </bindingElementExtensions> <bindingExtensions> <add name="wsHttpContextBinding" type="System.ServiceModel.Configuration.WSHttpContextBindingCollectionElement, System.ServiceModel, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/> <add name="netTcpContextBinding" type="System.ServiceModel.Configuration.NetTcpContextBindingCollectionElement, System.ServiceModel, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/> <add name="webHttpBinding" type="System.ServiceModel.Configuration.WebHttpBindingCollectionElement, System.ServiceModel.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"/> <add name="basicHttpContextBinding" type="System.ServiceModel.Configuration.BasicHttpContextBindingCollectionElement, System.ServiceModel, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/> </bindingExtensions> <endpointExtensions> <add name="dynamicEndpoint" type="System.ServiceModel.Discovery.Configuration.DynamicEndpointCollectionElement, System.ServiceModel.Discovery, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" /> <add name="discoveryEndpoint" type="System.ServiceModel.Discovery.Configuration.DiscoveryEndpointCollectionElement, System.ServiceModel.Discovery, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" /> <add name="udpDiscoveryEndpoint" type="System.ServiceModel.Discovery.Configuration.UdpDiscoveryEndpointCollectionElement, System.ServiceModel.Discovery, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" /> <add name="announcementEndpoint" type="System.ServiceModel.Discovery.Configuration.AnnouncementEndpointCollectionElement, System.ServiceModel.Discovery, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" /> <add name="udpAnnouncementEndpoint" type="System.ServiceModel.Discovery.Configuration.UdpAnnouncementEndpointCollectionElement, System.ServiceModel.Discovery, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" /> <add name="workflowControlEndpoint" type="System.ServiceModel.Activities.Configuration.WorkflowControlEndpointCollectionElement, System.ServiceModel.Activities, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" /> <add name="webHttpEndpoint" type="System.ServiceModel.Configuration.WebHttpEndpointCollectionElement, System.ServiceModel.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" /> <add name="webScriptEndpoint" type="System.ServiceModel.Configuration.WebScriptEndpointCollectionElement, System.ServiceModel.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" /> </endpointExtensions> </extensions> <client> <metadata> <policyImporters> <extension type="System.ServiceModel.Channels.ContextBindingElementImporter, System.ServiceModel, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089, processorArchitecture=MSIL"/> </policyImporters> <wsdlImporters> <extension type="System.ServiceModel.Channels.ContextBindingElementImporter, System.ServiceModel, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089, processorArchitecture=MSIL"/> </wsdlImporters> </metadata> </client> <tracking> <profiles> <trackingProfile name=""> <workflow activityDefinitionId="*"> <workflowInstanceQueries> <workflowInstanceQuery> <states> <state name="*"/> </states> </workflowInstanceQuery> </workflowInstanceQueries> <activityStateQueries> <activityStateQuery activityName="*"> <states> <state name="Faulted"/> </states> </activityStateQuery> </activityStateQueries> <faultPropagationQueries> <faultPropagationQuery faultSourceActivityName="*" faultHandlerActivityName="*"/> </faultPropagationQueries> </workflow> </trackingProfile> </profiles> </tracking> </system.serviceModel> <system.web> <processModel autoConfig="true"/> <httpHandlers /> <membership> <providers> <add name="AspNetSqlMembershipProvider" type="System.Web.Security.SqlMembershipProvider, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" connectionStringName="LocalSqlServer" enablePasswordRetrieval="false" enablePasswordReset="true" requiresQuestionAndAnswer="true" applicationName="/" requiresUniqueEmail="false" passwordFormat="Hashed" maxInvalidPasswordAttempts="5" minRequiredPasswordLength="7" minRequiredNonalphanumericCharacters="1" passwordAttemptWindow="10" passwordStrengthRegularExpression="" /> </providers> </membership> <profile> <providers> <add name="AspNetSqlProfileProvider" connectionStringName="LocalSqlServer" applicationName="/" type="System.Web.Profile.SqlProfileProvider, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" /> </providers> </profile> <roleManager> <providers> <add name="AspNetSqlRoleProvider" connectionStringName="LocalSqlServer" applicationName="/" type="System.Web.Security.SqlRoleProvider, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" /> <add name="AspNetWindowsTokenRoleProvider" applicationName="/" type="System.Web.Security.WindowsTokenRoleProvider, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" /> </providers> </roleManager> </system.web> </configuration>
you need to remove ALL the lines added by MainLobby, i.e.:
Code:<assemblyBinding xmlns = "urn:schemas-microsoft-com:asm.v1" > <dependentAssembly> <assemblyIdentity name="System.Runtime" publicKeyToken="b03f5f7f11d50a3a" culture="neutral"/> <bindingRedirect oldVersion="0.0.0.0-2.6.10.0" newVersion="2.6.10.0"/> </dependentAssembly> <dependentAssembly> <assemblyIdentity name="System.Threading.Tasks" publicKeyToken="b03f5f7f11d50a3a" culture="neutral" /> <bindingRedirect oldVersion="0.0.0.0-2.6.10.0" newVersion="2.6.10.0" /> </dependentAssembly> <dependentAssembly> <assemblyIdentity name="System.Net.Http" publicKeyToken="b03f5f7f11d50a3a" culture="neutral" /> <bindingRedirect oldVersion="0.0.0.0-2.2.29.0" newVersion="2.2.29.0" /> </dependentAssembly> <dependentAssembly> <assemblyIdentity name="System.Net.Http.Primitives" publicKeyToken="b03f5f7f11d50a3a" culture="neutral" /> <bindingRedirect oldVersion="0.0.0.0-2.2.29.0" newVersion="2.2.29.0" /> </dependentAssembly> <dependentAssembly> <assemblyIdentity name="Google.Apis" publicKeyToken="4b01fa6e34db77ab" culture="neutral" /> <bindingRedirect oldVersion="0.0.0.0-1.9.3.19379" newVersion="1.9.3.19379" /> </dependentAssembly> <dependentAssembly> <assemblyIdentity name="Google.Apis.Core" publicKeyToken="4b01fa6e34db77ab" culture="neutral" /> <bindingRedirect oldVersion="0.0.0.0-1.9.3.19379" newVersion="1.9.3.19379" /> </dependentAssembly> <dependentAssembly> <assemblyIdentity name="log4net" publicKeyToken="669E0Ddf0bb1aa2a" culture="neutral" /> <bindingRedirect oldVersion="0.0.0.0-1.2.14.0" newVersion="1.2.14.0" /> </dependentAssembly> </assemblyBinding>
