How do I control my thermostat using the Amazon Echo skill? I am not using the new API, but that requires you to say, "Alexa, tell HomeSeer to..." I tried with "set the heat to 69 degrees," which is what HS heard (because I took it from the log that said so) but Alexa says the device couldn't be found. The HS page for Echo integration uses that exact phrase as a supported command, and since the device shows up as a native thermostat with controls in HSTouch, I thought I would be able to use what HS says are thermostat commands.
Do I instead need to use the device name and say, "Alexa, tell HomeSeer to set the Target Temperature to 69?"
Scott
Scott
