How To Use RFXtrx433E On LAN?
    I understand there is a way to connect the RFXtrx433E to a Raspberry Pi and then connect to the Pi over the LAN? Is there a description of this? Can it then be used by the RFXCOM Plug-in or BLRF? Also does the RFXCOM Plug-in support multiple LAN connected RFXtrx433E?
    I have Qty 10 - 10 Channel Oregon Scientific temperature sensors all over and the one RFXrec433 that I have today does not seem to cover it all. So I was hoping to have more than one receiver but wanted to make sure that would be supported.
    Also saw a 433MHz 3dBi antenna with 1.5m cable, SMA male on the RFXCOM website. Would that in my attic on the my existing RFXrec433 maybe be a better idea?
    Any help and guidance would be appreciated.
    Jean-Marie G. Vaneskahian
    jean@vaneskahian.com
    Install ser2net on the RPI.
    Disable Serial Console (if configured)
    sudo nano /etc/inittab
    insert a # sign in front of this line:
    T0:23:respawn:/sbin/getty -L ttyAMA0 115200 vt100
    ctrl-O
    Enter
    ctrl-x
    Remove console (if configured)
    sudo nano /boot/cmdline.txt
    delete these 2 fields:  console=ttyAMA0,115200 kgdboc=ttyAMA0,115200
    ctrl-O
    Enter
    ctrl-x
    Add ser2net
    sudo apt-get install ser2net
    sudo nano /etc/ser2net.conf
    10001:raw:0:/dev/ttyUSB0:38400 8DATABITS NONE 1STOPBIT
    10002:raw:0:/dev/ttyUSB1:38400 8DATABITS NONE 1STOPBIT
    sudo /etc/init.d/ser2net restart
    Autostart ser2net
    sudo nano /etc/rc.local
    add the next line before exit o :
    /usr/local/sbin/ser2net -n
    The RFXCOM HS3 plugin supports:
    up to 6 RFXtrx/RFXrec devices in any mix and USB or LAN
    and up to 6 old RFXCOM receivers or W800RF32 in any mix and USB or LAN
    and up to 4 old RFXCOM transmitters
    BLRF can't use the RFXtrx. The +3dBi antenna improves the range a little bit. For the best results install this antenna on a metal plate of about 30cm. If you install the antenna in the attic install it upside down. You can buy this antenna also on ebay or aliexpress for a few dollar. Search for 3dBi magnetic antenna.
      You are awesome!!!! Thank you!!!!
        Can ser2net be setup on a Z-Net? Anyone using this with the Z-Net OS?
        Robert
          Robert
          yep. works well as the z-net OS is linux / raspberrypi os, specifically "Debian GNU/Linux". Bert's instructions are direct from the vendor.
          This is my ser2net config:
          #rfxcom
          Len
          HomeSeer Version: HS3 Pro Edition 3.0.0.435
          Linux version: Linux homeseer Ubuntu 16.04 x86_64
          Number of Devices: 633
          Number of Events: 773
          Enabled Plug-Ins
          2.0.54.0: BLBackup
          2.0.40.0: BLLAN
          3.0.0.48: EasyTrigger
          30.0.0.36: RFXCOM
          3.0.6.2: SDJ-Health
          3.0.0.87: weatherXML
          3.0.1.190: Z-Wave
            So I'm trying to set this up on my second Z-Net and it appears to just sit here....
            homeseer@PoolShedZ-Net /etc $ sudo apt-get install ser2net
            [sudo] password for homeseer:
            Reading package lists... Done
            Building dependency tree
            Reading state information... Done
            The following packages were automatically installed and are no longer required:
            libaudit0 liblightdm-gobject-1-0 libpciaccess0 libxkbfile1 libxklavier16
            lightdm-gtk-greeter x11-xkb-utils
            Use 'apt-get autoremove' to remove them.
            Suggested packages:
            telnet
            The following NEW packages will be installed:
            ser2net
            0 upgraded, 1 newly installed, 0 to remove and 19 not upgraded.
            Need to get 0 B/41.2 kB of archives.
            After this operation, 128 kB of additional disk space will be used.
            Selecting previously unselected package ser2net.
            (Reading database ... 68549 files and directories currently installed.)
            Unpacking ser2net (from .../ser2net_2.6-1_armhf.deb) ...
            Processing triggers for man-db ... <------
            Is this just the man pages? How long should this take? I don't expect too long. It's been at this for about 45 minutes.
              Suggested packages:
              telnet
              ser2net
              interesting. I would kill the process (control-c) and retry the command. I hate to suggest a reboot if that doesn't work.
              Len
              Enabled Plug-Ins
              2.0.54.0: BLBackup
              2.0.40.0: BLLAN
              30.0.0.36: RFXCOM
              3.0.6.2: SDJ-Health
              3.0.1.190: Z-Wave
                Yeah, I put it in the background because control-c didn't work. Even retried by putting the process back in the foreground and no go. I did end up rebooting and it seemed fine. It looks like ser2net restarted without issue.
                  When I try to connect to my new rfxcom transciever. I get the following trying to add a receiver:
                  Aug-07 11:06:19 AM RFXCOM 41 (Reconnect) receiver #3 try to reconnect.
                  Aug-07 11:05:25 AM RFXCOM 41 (Reconnect) receiver #3 try to reconnect.
                  Aug-07 11:04:31 AM RFXCOM 41 (Reconnect) receiver #3 try to reconnect.
                  Aug-07 11:04:13 AM RFXCOM Error: 41 (InitReceiver) Receiver #3 Error while connecting receiver on TCP 192.168.1.58,10001
                  Aug-07 11:04:13 AM RFXCOM Error: 41 (Connect) TCP error:System.Net.Sockets.SocketException (0x80004005): No connection could be made because the target machine actively refused it 192.168.1.58:10001 at System.Net.Sockets.Socket.Connect(IPAddress[] addresses, Int32 port) at System.Net.Sockets.Socket.Connect(String host, Int32 port) at HSPI_RFXCOM.clsSockets.Connect(String sRemoteHostName, Int32 iRemotePort, Int32 comType, Int32 intDev)
                  I followed post 2 verbatim as well as this post.
                  ... and when I tried to add a transceiver.
                  Aug-07 11:14:50 AM RFXCOM 41 (Reconnect) transceiver #1 try to reconnect.
                  Aug-07 11:13:57 AM RFXCOM 41 (Reconnect) transceiver #1 try to reconnect.
                  Aug-07 11:13:56 AM RFXCOM Error: 41 (InitTRX) error Transceiver #1 Error while connecting transceiver on TCP 192.168.1.58,10001
                  Aug-07 11:13:56 AM RFXCOM Error: 41 (Connect) TCP error:System.Net.Sockets.SocketException (0x80004005): No connection could be made because the target machine actively refused it 192.168.1.58:10001 at System.Net.Sockets.Socket.Connect(IPAddress[] addresses, Int32 port) at System.Net.Sockets.Socket.Connect(String host, Int32 port) at HSPI_RFXCOM.clsSockets.Connect(String sRemoteHostName, Int32 iRemotePort, Int32 comType, Int32 intDev)
                    you have to use the RFXrx/RFXrec configuration for the RFXtrx433XL transceiver.
                    Are you able to connect the RFXtrx over LAN with RFXmngr?
                      OK.. most bizzar thing ever. I modified and saved /etc/ser2net.conf
                      homeseer@PoolShedZ-Net ~ $ tail /etc/ser2net.conf
                      BANNER:banner:\r\nser2net port \p device \d [\s] (Debian GNU/Linux)\r\n\r\n
                      #2000:telnet:600:/dev/ttyS0:9600 8DATABITS NONE 1STOPBIT banner
                      2001:raw:60:/dev/ttyAMA0:115200 8DATABITS NONE 1STOPBIT -XONXOFF -RTSCTS
                      2002:raw:60:/dev/ttyUSB0:19200 8DATABITS NONE 1STOPBIT -XONXOFF -RTSCTS
                      #3000:telnet:600:/dev/ttyS0:19200 8DATABITS NONE 1STOPBIT banner
                      #3001:telnet:600:/dev/ttyS1:19200 8DATABITS NONE 1STOPBIT banner
                      #rfxcom
                      10001:raw:0:/dev/ttyUSB0:38400 8DATABITS NONE 1STOPBIT <---saved
                      and rc.local
                      homeseer@PoolShedZ-Net ~ $ tail /etc/rc.local
                      # stop led blink
                      #echo 0 > /sys/devices/platform/zwled.0/iopin
                      # set LED to green
                      #echo "3" > /sys/class/gpio/export
                      #echo "out" > /sys/class/gpio/gpio3/direction
                      #echo "0" > /sys/class/gpio/gpio3/value
                      sudo /var/www/Main/monitor.sh &
                      /usr/local/sbin/ser2net -n <----- saved this as can be seen when I tail the file.
                      exit 0
                      However, after a reboot, they're gone.
                      Any ideas?
                      Robert
                        Could be a bad SD card.
                          I don't know... I will try again with a new sd card. Just seems so weird as I set the sytem date and time yesterday, modified the files then did a long listing and saw the updated date on the files. After a reboot this morning, my saved settings are no more.
                            In case anyone runs across this, I finally imaged to a new SD card and now settings persist.
