Originally posted by spud
View Post
Plugin stopped reading Nest data
I take that back. Seems when I do "too many requests"? Really it only takes like 3-4. Pardon my ignorance but are there logs specific to the nest plugin or do you want my homeseer logs. I put a snippet of what I am getting with debug on.
Aug-01 6:13:01 PM Nest DEBUG System.AggregateException: One or more errors occurred. ---> System.Net.Http.HttpRequestException: Response status code does not indicate success: 429 (Too Many Requests). at Microsoft.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSu ccess(Task task) at Microsoft.Runtime.CompilerServices.TaskAwaiter.HandleNonSucc ess(Task task) at FirebaseSharp.Firebase.d__3.MoveNext() --- End of inner exception stack trace --- at System.Threading.Tasks.Task.ThrowIfExceptional(Boolean includeTaskCanceledExceptions) at System.Threading.Tasks.Task`1.GetResultCore(Boolean waitCompletionNotification) at System.Threading.Tasks.Task`1.get_Result() at NestSharp.NestClient.SetTargetTemperature(String thermostatId, Double target, String scale) at HSPI_Nest.NestApp.ButtonPress(String buttonName, Double value, Int32 dvref) ---> (Inner Exception #0) System.Net.Http.HttpRequestException: Response status code does not indicate success: 429 (Too Many Requests). at Microsoft.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSu ccess(Task task) at Microsoft.Runtime.CompilerServices.TaskAwaiter.HandleNonSucc ess(Task task) at FirebaseSharp.Firebase.d__3.MoveNext()<---
Aug-01 6:13:01 PM Nest ERROR One or more errors occurred.
Aug-01 6:13:00 PM Nest DEBUG PUT: path=devices/thermostats/SyE5pSBxL4Ny3e7pjueSjw_VumSUMP-v payload={"target_temperature_f":78}
Aug-01 6:13:00 PM Device Control Device: Nest Target Temperature High to + (1001) by/from: CAPI Control Handler
Aug-01 6:12:57 PM Nest DEBUG System.AggregateException: One or more errors occurred. ---> System.Net.Http.HttpRequestException: Response status code does not indicate success: 429 (Too Many Requests). at Microsoft.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSu ccess(Task task) at Microsoft.Runtime.CompilerServices.TaskAwaiter.HandleNonSucc ess(Task task) at FirebaseSharp.Firebase.d__3.MoveNext() --- End of inner exception stack trace --- at System.Threading.Tasks.Task.ThrowIfExceptional(Boolean includeTaskCanceledExceptions) at System.Threading.Tasks.Task`1.GetResultCore(Boolean waitCompletionNotification) at System.Threading.Tasks.Task`1.get_Result() at NestSharp.NestClient.SetTargetTemperature(String thermostatId, Double target, String scale) at HSPI_Nest.NestApp.ButtonPress(String buttonName, Double value, Int32 dvref) ---> (Inner Exception #0) System.Net.Http.HttpRequestException: Response status code does not indicate success: 429 (Too Many Requests). at Microsoft.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSu ccess(Task task) at Microsoft.Runtime.CompilerServices.TaskAwaiter.HandleNonSucc ess(Task task) at FirebaseSharp.Firebase.d__3.MoveNext()<---
Aug-01 6:12:57 PM Nest ERROR One or more errors occurred.
Originally posted by jayman13 View PostI take that back. Seems when I do "too many requests"? Really it only takes like 3-4.
the Nest API apply some rate limits, there is a maximum number of requests one can do for a given period of time. From what I read this maximum is one request per minute with a one hour sliding window, meaning that you can do 60 request in 1 minute but then you won't be able to do anymore request for the next hour.
for more info read this:
http://stackoverflow.com/questions/2...mitations-last
https://developer.nest.com/documenta...ta-rate-limits
so, wait a day or two, then you should be fine
Gotcha. Thanks. So about 1 call per minute is the recommendation. That seems pretty lame (conservative) to me. It is google now after all, isn't it?
Hometroller
Spud,
Did you ever get the Nest plug in to work with Hometroller with XP? Paid for the app but never got much use on it after the June 11 error messages. Was waiting a couple months to see if it could be fixed. Not really wanting to upgrade after spending the cash for the Hometroller.
Thanks Brent
Thanks Brent
Windows XP support ended, more and more libraries now needs NET 4.5 to run which can't be installed on XP, so you will get more and more troubles if you try to install new plugins or software on your hometroller.
mine also stopped working
RROR Kan bestand of assembly Newtonsoft.Json, Version=7.0.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed of een van de afhankelijkheden hiervan niet laden. De manifestdefinitie van de gevonden assembly komt niet overeen met de assembly-verwijzing. (Uitzondering van HRESULT: 0x80131040)
any toughts?
any toughts?
The Newtonsoft.Json.dll should be in bin/Nest only
Originally posted by akatar View Postno, there is no version in the homseer 3 root
what other plugins do you have installed?
you can try to copy the file bin/Nest/Newtonsoft.Json.dll in your HS3 root folder, then restart the plugin. However this method is likely to cause conflicts if other plugin use the same dll.
Originally posted by akatar View Posti am sure
i copied the json file. restarted hs3 en other plungins started to crash, deleted it and all works fine
which other plugins started to crash?
Originally posted by akatar View Posti added lots of plugins
