Actually, it seems it isn't the tabs, rather a LF (hex 0A) in there that makes life hard for the sign. I actually got the replace to work with the tabs, but the 0A won't work.
Jon00 DataScraper/JSON Parser Script For Homeseer 3 and Homeseer 4
Try Version 1.0.7 on my site.
I have added the following tags to the replace function:
{CHRXX} where XX is the decimal number for the ASCII character.
I have not tackled the spaces, however the following should work:
DeviceText1=Veimelding RV159 [0] [Replace "{CHR13}",""] [Replace "{CHR10}",""] [Replace "{CHR9}",""]
Formatted String
Jon00,
I get the text I want returned via the regex I've constructed but the <br> html code is being stripped and replaced with no character. So I get GrilledCheese as opposed to Grilled Cheese. Other sections of the text returned have spaces embedded in them and this works fine. I'm sure I need to add a replacement string but don't know where to begin. Replacing <br> with space would most likely fix my issue.
HittR
Jon,
I'm no expert in coding but this is what i found.
These look like the statements i would need to scrape.
<div class="sp-energy-mix-label" translate="FROM_SOLAR">From Solar</div>
<div class="sp-energy-kws">5.3 kWh</div>
<div class="sp-energy-mix-used" translate="TOTAL_ENERGY_USAGE">Total Energy Used</div>
<div class="sp-energy-kws">10.7 kWh</div>
<div class="sp-energy-mix-label" translate="FROM_GRID">From Grid</div>
<div class="sp-energy-kws">5.4 kWh</div>
They were taken from this page. But I am not sure how to tell if I can scrape the data.
That should scrape well.
Try the following pattern:
Pattern1=(?s)"sp-energy-kws">(.*?)</div>
It should give you all the results back in the ini file under 0, 1 , 2 etc. As they will always be in the same order. you just need to work out which metric is which and assign a device to each one.
If you just want the value, amend the pattern as:
Pattern1=(?s)"sp-energy-kws">(.*?)kWh</div>
Originally posted by jpape View PostI seem to have a problem as the first screen i get when going to the site is a login screen, once logged in i then need to get to the screen i posted above. i does not look like i can do that from your ini file as it only accepts one URL.
Jon, would you agree with the above statement or am I missing an option?
Judd
Jon, Thanks for spending the time with me on this.
So once I log onto the website, the first page does have the information i'm looking to scrape so i don't need to go to another screen. But when i execute the script, nothing seems to be happening. Is there any debug log that is produced?
This is the logon screen https://monitor.us.sunpower.com/#/login and once logged in it brings me to the screen with the data.
Judd
