Hello MikeMack,
I'm trying to upgrade my homeseer system to new debian version and especially mono runtime 3 to version 4. (hslinux).
I restored the hs3 config to the new host, installed the scenemaster plugin.
then I noticed the scene config is not there. When I enable the debug option and restart the plugin there I can see it finds the scene config but then throws an exception and then deletes devices.
Is this issue related to mono version4?
Zigmund
Zigmund
Apr-16 13:38:41 Plug-In Finished initializing plug-in SceneMaster Apr-16 13:38:41 4 SceneMaster HSPI_scenemaster.HSPI [HS] - Plugin Init Complete. Plugin version: v1.2.2.0, HS API v3 Apr-16 13:38:41 4 SceneMaster HSPI_scenemaster.GenTimer_c [HS] - Starting Timer Apr-16 13:38:41 4 SceneMaster HSPI_scenemaster.GenTimer_c [HS] - Starting Timer Apr-16 13:38:41 4 SceneMaster HSPI_scenemaster.Util [HS] - Deleting Orphaned SceneMaster Device: 1400 Apr-16 13:38:40 2 SceneMaster HSPI_scenemaster.Util [HS] - Exception in Find_Create_Devices/Enumerator: Object reference not set to an instance of an object Apr-16 13:38:38 4 SceneMaster HSPI_scenemaster.Util [HS] - Init: Found Scene:woonkamer-verlichting Apr-16 13:38:38 4 SceneMaster HSPI_scenemaster.HSPI [HS] - Plugin Init Started.. Plugin version: v1.2.2.0, HS API v3 Apr-16 13:38:38 Info Plugin SceneMaster has connected. IP:127.0.0.1:41425 Apr-16 13:38:36 Plug-In Interface SceneMaster is running as a trial, 30 days remaining. Apr-16 13:38:27 Info Plugin SceneMaster with instance: has disconnected Apr-16 13:38:27 Plug-In Shutting down Plug-In: SceneMaster Apr-16 13:38:20 3 SceneMaster HSPI_scenemaster.SetupWebPage [HS] - Log level changed to: DEBUG
