Backup HAI config
    Backup HAI config
    Is there a method for backing up the entire HAI plugin configuration - like there is for backing up the HS system config? IMHO, it would be very useful.
    I would recommend just a nightly HS backup and that will get everything.
    Sent from my SM-G935U using Tapatalk
    HS4Pro on a Raspberry Pi4
    HSTouch Clients: 1 Android
      [QUOTE=rmasonjr;1305288]I would recommend just a nightly HS backup and that will get everything.
      Sent from my SM-G935U using Tapatalk[/QUOTE
      Keeping in mind I have a Hometroller Zee II, how exactly would I do that?
      Thanks for your help!
        Having experienced the hassles of not backing up ... I assumed I needed to shut down HS3 to backup my "c:\program files (x86)\HomeSeer HS3". Sounds like maybe I do not need to shutdown. Have people had good lucking copying off the folder while HS3 is running?
          Here's how I backup my RPi each night. It will work on a Zee as well.
          It basically tars the entire folder up and keeps 7 days of backups.
          Note that these backups are on the SD card, so I periodically move them off manually.
          I have had to restore them before and it has always worked fine.
          First, create a script in the /home/homeseer folder - I called mine: backuphs3.sh
          You'll need to chmod a+x backuphs3.sh to make it executable.
          #!/bin/bash
          BACKUP_FILE=HS3_`date +%Y%m%d`.tar.gz
          cd /home/homeseer
          tar -zcvf $BACKUP_FILE /usr/local/HomeSeer
          rm -f $(ls -ltr HS3_* |head -n -7)
          Now, create a HS event to run the script:
            +++ Rob.
            Here do similar to Rob. I also do a manual backup when updating Homeseer or plugins.
            It is not really time consuming and easy.
            So as not to have to build a new SD image you can also back up the entire SD card say once a month if you want. Here I standardized to a 16Gb SD card for all of my RPi builds.
            Looking at the space utilization it is less than half of the 16Gb such that an image can be compressed.
            I shut down Homeseer. Copy the directory over to whatever PC I am on. I then rename the directory to something like HomeseerVXX-backupDate. I then copy this directory to a backup directory on the SD card (which eventually gets backed up to a NAS).
            I then update the Homeseer directory. If it fails or I see issues I just shut down Homeseer and rename the directory to something like HomeSeer.bad and copy back the before updating directory.
            All of the above takes only 5 minutes to run manually and backing up the whole Homeseer directory insures that you got it all intact.
            If you are on a windows computer you can utilize WinSCP to do this talking to a Linux build. I do Linux laptop to Linux Homeseer build and the file manager works the same as in WinSCP.
