I'm trying to figure out why I can't assume my HomeSeer unit from my iPhone. It worked on my previous phone, but I had a network issue for a while and got really busy so I didn't have a chance to work on it. I ended up changing my phones and now I can't seem to get HSTouch to connect with either phone. I think I've upgraded to iOS9 since the last time I connected. Has the app stopped working with iOS9? I'm on my local network and trying to connect. I only have 2 users configured and right now I have them both with the same password on HomeSeer software. When I open HSTouch, it says connecting, but just times out. Some times it will say Getting Data and then time out. On the software, I can see that the ip address is coming in and says CONNECTED. But nothing on the phone. Anyone have any thoughts? Thanks.
HSTouch not logging in
I'm not using a myHS connection. I just use the local server I set up with the ip address and login info. I don't have HS3 as I'm looking to get a dedicated pc to run it. I'm running HS2 version 2.5.0.4, but I haven't changed that version in a long time and it was working on that before. The HSTouch iPhone and Server plugin versions are 1.0.0.2 and 1.0.0.60 respectively. I'm guessing since I have a very old version, that these haven't had updates released in a while. It seems like the only change I've had is iOS9 which makes me nervous that it won't work.
