I am using the Hometroller Zee S2 and one of my plugins access HTTPS feeds and apparently.....
"...To fix this you will need to install the CA and intermediary CA public certs onto the Zee, otherwise the connection will be refused as the feed's page (server cert) won't be trusted....You will need to install both the Entrust.net and Entrust Certification Authority -L1K into the root CA store on the Zee."
I found the certificates at https://www.entrustdatacard.com/page...cates-download
entrust_2048_ca.cer
entrust_l1k.cer
and downloaded them to my Windows pc.
I have no experience with Linux etc. (which I assume is the underlying OS) and I was wondering
a) how/where do I copy them onto the Zee
b) do I have sufficient user privileges?
c) do I then just run the command: sudo update-ca-certificates ??
I feel like I'm REALLY close on this.
Any and all advice is most welcome
Merry Christmas!
entrust_2048_ca.cer
entrust_l1k.cer
Merry Christmas!
